Chain and spockets
Discussion in 'General 1000RR Discussion' started by bazzashadow, Jun 10, 2024.
  1. gentlybently
    gentlybently Active Member
    very true. McGuinness used to race with cABS on his leathers but we all know he wouldn't of even ridden a road bike with that system on.
  2. Manofsteel
    Manofsteel Well-Known Member
    Funnily enough his 2016 Fireblade SP road bike had c-abs on and quite large chicken strips
  3. Selmer50mark
    He rocked up at Devils bridge one morning on that bike and got the piss taken out of him for his strips, he saw the funny side and to be fair to him it was new and wet roads . He'd still be quicker than us with strips ;)
    Pulled a cracking wheelie on his way out :D
    • Optimistic Optimistic x 1
  4. Broadie
    Broadie Active Member
    @bazzashadow
    I've seen a guy on my telly with 44 teeth on his leathers. Maybe of interest to you
    #24 Broadie, Aug 27, 2024
  5. Lozzy
    Bazzas from Norfuck.....he can only dream of having 44 teeth :D
    • Funny Funny x 6
  6. dgr
    dgr Active Member
    Smaller sprocket on the front and larger sprocket on the rear will both shorten the gearing, so you will be at a higher rpm for a given speed in a given gear than stock. Usually gearing is shortened to improve acceleration, at the expense of top speed. The shorter the gear, the higher the torque, but lower power.
    Both changes from stock will affect the speedo in the same direction, so it will read too high.
  7. CharlieR85
    Much prefer standard gearing for the road. Find 15-44 makes everything a bit too revvy. It's great on the track though.
