well the Tiger's not been run since Oct/Nov, So gave her a good going over today. changed and replaced oil and filter, Fuel filter, all over check and glad I removed the Nose as the rad fan was loose and only held on with 3 bolts. and the other 3 were loose. under sealed the rear and painted the diff. front suspension cleaned and painted. larger better Fan on order, 14" to replace the 10". adjustable rad thermostat will be picked up this week. moving the water temp sensor to the front of the car as it's too close to the exhaust. lots done and lots to do But the result the cars 100% ready for le mans, the spring and the only issue which is the temp when on track days or warms weather will be sorted
Tis great fun. And after 10k,euro trips and track days etc... It's still fun over 8 years later. But the bike is different league to the car
