Motorcycle trailer - What to look for...
Discussion in 'Mods, Upgrades, Accessories and Products' started by Remal, Feb 3, 2012.
  1. Remal
    ... make etc..
    I used last year a double trailer which was not very good for holding the bike upright as it only had a small front wheel bracket.
    As I don't need/use a van what do I need to look for with a trailer? I have space to store one that does not fold?
    What makes, links etc... can people provide so I can find out more
    cheers all
  2. kpone
  3. dan.1moore1
    Made mine my self
  4. Repsol Rob
    Repsol Rob Elite Member
    Come on then Dan prove it !!!!!!!!!! lol
  5. dan.1moore1
    I gotts go out in the bloody cold !! lol Gimme a sec and ill go get some snaps .
  6. dan.1moore1
    Here she is . Picked most of the parts up at an auto jumble .
    At the time my mum was a secretary at a local engendering firm so I bought all the box section , bar and cheq plate cheap .
    Not bad for a GNVQ in welding ey ?
    ok I'll come clean . I had alot of help from my Engineer grandfather Lol
    All the messy welds underneath are mine thou ha ha
  7. damodici
    damodici Active Member
    Trelgo and erde are both good mate, as are dave cooper.
    YOu can fit a bump stop like I have done to mine and then just buy a tyre down (best invention for track day trailers ever)
    You can load a bike on your own no problem and with the tyre down you don't crank down the suspension so it's easier on the fork seals
  8. r1monkey
    r1monkey Active Member
    i have a single bike trailer .the best thing i bought for it is a "bike wheel chock" (put it in a search on ebay they are about £60 plus post.)
    i have welded it to the front of my trailer , you simply start the bike up put it in gear and walk the bike into the bike chock.
    as the bike goes over the pivot point stop the engine ,and the bike is held upright by the front wheel .You can really swing on it without fear of it falling over.
    you can then let go of the bike and put your ratchet straps on without fear of the bike falling over as you fight with the ratchet straps.
    it also means that you dont have to get the wife out of bed at 5.30am to hold the bike up whilst you fasten it down.
    (once broke the wifes finger whilst loading up my trackbike ,she wasnt too happy about it .) but it was ok , it didnt spoil MY day.
  9. rocket
    rocket Active Member
    i have an erde single bike trailer that is perfect for my needs. has adjustable hoop to secure front wheel good tie down points and is only 60 odd kg empty so easy to carry around if needed to store. only downside is quite narrow axle but still tows stable enough.
  10. dazza
    dazza Active Member
  11. damodici
    Tyre Down Review
    Until you've used one you just can't imagine how much better these are than multiple ratchet straps.
    Honestly that good
  12. Remal
  13. Remal
    cheers guys for the helpful replys
  14. Garyb
    Garyb Moderator.
    Unsure of trailers?
    I had looked at purchasing one of these when i was thinking track bike, the car was well capable of the job, but XXXXXX would not put their reputation on the line when it came to the ability of the nose weight placed upon their towball, a few engineers at work reckon it would be super simple to fit and easy to adapt if required and reckoned XXXXXX was talking shit, basicly because its not a direct force more a cantilevered effect, anyway, take a look see what you think?
    Towbars, Front push tow bars, towing brackets specialists from Watling Engineers | Watling Motorack - Scooter and Motorbike Carrier
    Edit. this is only the principle, not the actual one i looked at, it was capable upto 600lb
    #14 Garyb, Feb 4, 2012
  15. Brym
    Brym Active Member
    Just spotted this haha glad it didn't spoil your day
  16. Remal
    Pulling caravans I kno even a large twin axle caravan only puts a maximum of 100kg on the towable and less is better. So even with no fuel putting a 180+kg blade on thatis a no no n my opinion
  17. Swiss T
    Swiss T Active Member
    Pretty much ditto (except the finger lol). :)
  18. slowr1der
    slowr1der Active Member
    I may have my 3 bike trailer up for sale soon, will let you know
