Brake Fluid ?
Discussion in 'Maintenance' started by daveyboy, Apr 13, 2012.
  1. daveyboy
    daveyboy Active Member
    I have my brake fluid changed every service. I trust the guy who does it but almost straight away it starts to look like monkey piss ! WTF !
    Has anybody got any ideas?
    If it helps I had some braided lines put on, front and back about 2 years ago.
    It's making me paranoid now, even to the point where I have had to by some Repsol covers for the reservoirs !!
  2. tandbiskits
    tandbiskits Active Member
    Try a different colour fluid, what colour is monkey piss? SURELY AS LONG AS THEY WORK O.K. IT DOESN`T MATTER WOT COLOUR IT IS. IiS IT A COLOUR THING OR A BRAKE FEEL THING?
  3. kpone
    Nutty uses purple brake fluid, but that looks like George III's piss.
  4. BLAGGERS
    BLAGGERS Well-Known Member
    I simply cut out the middle man and piss in the reservoir.
  5. IcarusGreen
    IcarusGreen Elite Member
    Brake fluid should be a pale 'piss' colour, as it starts to darkens it is 'going off'. Brake fluid is also 'hydroscopic' which means it will absorb water molecules from the air, making it less efficient.
  6. kpone
    Unlike Blaggers, who is hydrophobic, because he has Rabies.
  7. daveyboy
    Doe that make him "grease lightning" :D
  8. kpone
    Well he flashes...
  9. tandbiskits
    I have just fitted new brake lines & have refilled with ATE racing brake fluid, which is a very nice shade of blue. Regards to it being a pale` piss` colour, if you piss out blue then you have got problems? unless you drink alot of WKD blu.
  10. IcarusGreen
    Apparently if you eat enough beetroot you'll piss purple :eek:
  11. tandbiskits
    I`ll give it a go
  12. IcarusGreen
    Let us know of your results, with photos!
  13. tandbiskits
    If i eat enuf nutella, wot will happen then?
  14. Givover
    Suprise us with your results.lol
  15. fez.57
    fez.57 Well-Known Member
