Project rebuild
Discussion in 'Mods, Upgrades, Accessories and Products' started by gixerator, May 5, 2012.
  1. gixerator
    gixerator Active Member
    Following my slow speed off into the kitty litter at oulton, im starting to re-build the beast.
    Jobs to do:-
    Replace LHS Mid fairing
    Replace upper Fairing (carbon),
    R&G Generator cover,
    Motographix number board,
    Fit Carbon Belly pan,
    Fit R&G Areo Sliders,
    Flapper mod to air tubes,
    Paint scratches to swing arm and tank,
    This should have been an easy job, but washers are to big and needed re shaping to fit!!
    Left hand fairing off and flapper out, I have shaped a round(ish) cover out of an old air tube cover. Does anyone know if the collector in the nose can be removed as well without a fault code?
  2. gixerator
    Here is the nose ready to go on (pre preg)
    Number board, not sure wether to use the smaller ones next to the lights yet.
    Now for the scratches,
    #2 gixerator, May 5, 2012
  3. dan.1moore1
    Make her bigger and better mate ..
    How long did the belly pan take to come . 60 odd bloody days i waited for mine . Well worth it thou
  4. gixerator
    took about 45 days, I have put far too much heat shield on it and made it heavier than standard. I will take some off as its not near the exhaust.
  5. gixerator
  6. Benn The Pig
    Shows the quality of the paint if that's the only scratches on the swing arm!!!
  7. gixerator
    That and the new LHS Fairing and nose cone
  8. gixerator
    All finished, a bit pic heavy but here goes,
  9. raphael
    yep like that! a lot
  10. lee711
    lee711 Active Member
    Lookin good Adam, thats a spot on job mate. :)
  11. Jamiestrada
    Stunning, love it and want that ohlins rear shock :)
  12. Pinkster1000RR
    Pinkster1000RR Active Member
    Looking great Adam mate :)
  13. gixerator
    It turned out less useful than a set of wets would of been, I can test it more now the bike is back together.
  14. Jamiestrada
    swap you some wets then ;) lol
    Still looks great :D
