Alpha Suspension set up
Discussion in 'General 1000RR Discussion' started by Carl, Jul 21, 2011.
  1. Carl
    Carl Well-Known Member
    I understand that Alph Suspension set up will be at Willingham Woods Sunday 24th July, £25 for a full set up. From 10am
    ALPHA SUSPENSION SET-UP - News
    Not sure if its any good, anyone know?
  2. Hondo
    Hondo Active Member
    Its very good. He's doing my bike on Sunday at Willingham. Spoke to him last night. He seems a great chap and very helpful.
  3. dan.1moore1
    Dam,, to far for me
  4. BladeHRC
    BladeHRC Active Member
    I'm thinking about a trip over to K-tech in Derbyshire one day for a suspension setup session. My suspension is on totally standard settings at the moment. I'm just under 13stone at the moment, so dont know if the standard settings are close to being right for me? Road surfacing is pretty bad in places here in Snowdonia and I noticed a hell of a difference changing the OEM Bridgestones for Diablo Rosso II's. Takes the uneven surfaces and crappy tar spraying more in its stride now. Hoping for a similar improvement again from fettling the suspension.
    What is the general consensus on the standard settings (too hard, too soft, not enough damping etc?)
  5. BladeHRC
    Reply from K-tech today...
    Hi Gareth
    We can offer you a ride in /ride out set up for your bike, this takes around
    30 minutes and includes checking the front and rear spring preload (sag) and setting the compression and rebound adjusters for optimum performance of the standard units. If you would like to have this work carried out on your bike please give our workshop a call on 01283 559 004 and they will make an appointment for you to do this. We normally need around three working days to make this appointment and charge 35.00 + VAT to carry out the work.
    Best Regards
    Chris Taylor
    K-Tech Suspension Ltd
    Units 1 & 2 Marquis Court
    Rawdon Business Park
    Moira
    Derbyshire
    DE12 6EJ
    Mail:- [email protected]
    Tel:- +44 (0) 1283 559 001
    Fax:- +44 (0) 1283 480 746
  6. flatstickHRC
    flatstickHRC Active Member
    I guarantee they will try to sell you front springs and a revalve!
    Your rear spring will be ok for your weight but the front end is oversprung and the rebound is far too fast
    I found +1 turn rebound - 0.5 turn comp works well on he front.
    I have bought a lot from k tech in the past (shocks and cartridge kits as well as sending shocks for re valve etc).
    I found they didn't give any support regarding set up but maybe a ride in/out service would be better.
    I left the rear alone for now.
  7. dazza
    dazza Active Member
    They are, literaly, round the corner from me so would be interested in the results if you go for the service. Need to get my Blade and track Kwak B1h set up.
    Keep us updated please. :)
  8. SimonRR
    SimonRR God Like
    just had a word with John from Alpha suspension, he is willing to come to somewhere in Lincs to set up our suspension if we can get 8+ bikes?
    so if anyone would like their bikes suspension set up please let me know here or pm me and if we get 8 or more i will try sort something out?
    it will work out at £30 per bike :)
    Simon
    #8 SimonRR, Feb 26, 2013
  9. Carl
    I'm in Simon however I'm on holiday soon so I'll liaise when you have the numbers?
  10. blade1980
    blade1980 Active Member
    If be up for that for sure
  11. SimonRR
    SimonRR God Like
    OK guys just to carry this thread on, Alpha suspension setup will be at Grantham Honda for the Honda new bike promotion day on 20th April, weather permitting?
    A custom bike setup will be just £30 and there will be a BBQ, Music, babes and so on...
    should be a good day :D
    ALPHA SUSPENSION SET-UP - Welcome
    Simon
    #11 SimonRR, Mar 14, 2013
  12. blade1980
    Will be there!
  13. callumw
    callumw Active Member
    I'm getting mine set up by Steve Jordan on the 23rd.
    Hoping for a good setup and some advise on different setups
  14. sinewave
    Sounds more like an organised 'Dogging' session down in the Woods! :D
  15. Muffking
    What time are you going?
    I need to work out if i can be ready in time due to the late finish the noght before.
  16. SimonRR
    SimonRR God Like
    I reckon I will go mid morning but will stay for a good while, gotta make use of the bbq, music and babes :D
    alpha will be there all day so no need to rush :D
  17. Muffking
    Jobs a good 'un.
    Where abouts is grantham honda (without stating the obvious). Last time i went to look for it i failed :-0
  18. SimonRR
    SimonRR God Like
    which way you coming in from?
  19. sinewave
    ......................the outside! :D
  20. Clarkey
    Clarkey Member
    Where is Steve Jordan based
