When disconnecting the O2 sensor what did you do?
Discussion in 'Maintenance' started by phantomx0_1, Jul 6, 2012.
  1. phantomx0_1
    phantomx0_1 Active Member
    When disconnecting the O2 sensor from the standar exhaust what did you do. I've traced the wire back and fitted the elimiator did you totally remove the O2 sensor or tie it up somewhere to save hassle when going back to standard?
    Thanks
  2. Si.
    I left mine in the can, and tied it out of the way.
  3. phantomx0_1
    Just traced the wire and not as much of a pain a I thought so have removed it.
  4. 1000rr73
    1000rr73 Active Member
    That's what i'd do rather than cable tieing it up somewhere..., now go lose it in your garage somewhere to never be found again when you need it most.
  5. phantomx0_1
    It's off now to be lost in the abyss that is my garage!
