Which oil for RR5?
Discussion in 'Maintenance' started by Muffking, Jul 18, 2012.
  1. Muffking
    As i'm on the minimum at the moment and considering a DIY oil service, I wondered what oil you '04-'07 guys were using and what grade as it's difficult to tell from the handbook.
  2. robinh73
    robinh73 Well-Known Member
  3. Remal
  4. Muffking
  5. robinh73
    That's cheap that is. I think it normally retails for about £40-£45.
  6. ray
    ray Well-Known Member
    Always had Castrol Power 1 4T 10w-30 (Semi-Synthetic) put in mine from the dealer.
  7. wedgiewolves#223
    wedgiewolves#223 God Like
    Dear Mr Wedge,
    Thank you for contacting Honda UK.
    Honda UK recommends using Castrol Power 1 Racing 10W-30 for your Fireblade.
    W
    e hope this clarifies your query.
    Kind regards
    Stephen
    Honda UK Contact Centre
  8. phantom
    phantom Active Member
    use the same stuff :D
  9. BLAGGERS
    BLAGGERS Well-Known Member
    Yep. Semi synth, 10/30. Castrol. Tastes slightly better than silkolene too. (dont ask)
  10. wedgiewolves#223
    Not by any chance over filled and you was trying to suck it out up a tube ? :D
  11. Jonny fireblade
    Jonny fireblade Active Member
    I use motul semi synthetic now, i have tried the fully synthetic but found the gearbox clunked into 1st much better with the semi
  12. honda.ima
    honda.ima Active Member
