Hi can anyone take a pic of how the left hand side wiring is routed particularly the big 20 pin connector (from top of rad to lights/clock), or described how it’s routed. Mine seems to catch a bit on the forks now I’ve put standard fairing on, not sure if someone shortened it a bit when they converted it to track bike. Should it route inside the fairing infil? Cheers Mike
You might need someone with the tank etc off so I don't know whether this helps. All mine run across the top behind the tank:
Thanks Nigel, it more where it goes once it dips down across the top of the radiator, and how it’s routed after that. Prob have to wait until someone next has their fairing off. Cheers Mike
Perhaps PM @PauloHRC. He's in the middle of changing his fairings to matte black. You might be just in time before he completes.
Jesus Nigel. ......first and dirty back box, now you've got a filthy screw hole!!! Yes fairings off at the weekend coming so I can update you with pics then!
