2008-11 vs 2012-14 Headers
Discussion in 'Mods, Upgrades, Accessories and Products' started by si1000repsol, May 12, 2014.
  1. si1000repsol
    Are there any significant difference between the exhaust headers? Are they changed mostly due to the new fairings?
  2. Jamiestrada
    Think cylinders 2 and 3 are linked and there is a cat attatched to the headers on the 2014 bike
    08 - 13 are the same as far as i know
  3. si1000repsol
    I thought they were different on the SP but they have the same p/n as the 2012 headers. This is why I wonder why the P/N is not common to the 08-11 models too.
  4. Jamiestrada
    They are defo different on the SP (2014) to the 2013 I have thats why there have been so many issues fitting end cans.
  5. si1000repsol
    Yes just revisited the part number and yes it differs from the 2012 headers
    18150-MGP-A90 2014 SP
    18150-MGP-A00 2012-2013
    There is yet another part number for the 08-11 so not sure what is going on with them?
    #5 si1000repsol, May 12, 2014
  6. Gilesy
    Gilesy Elite Member
    pic of the SP ones I took off last week
  7. si1000repsol
    They look different to the stock headers on the 08-11!!
    br3874-2008-2011-honda-cbr1000rr-exhaust-header-manifold-oem-08-11-pipes-pipe-headers-3.jpg
  8. 1000rrboyjay
    1000rrboyjay Active Member
    So will a 2014 full system go on an 08?
  9. Dave dunlop
    Dave dunlop Elite Member
    As far as I know 14/16 headers all the same including SP were reduced to increase midrange, 12/13 headers were bigger OD downpipes, 14/16 cat is now built in to the pipe and all models pre 14 had the cat in the end silencer.
  10. Dave dunlop
    The only difference between 2014 engine and SP is the SP engine is blueprinted...
    SP CBR1000RR. Honda put their engineers to work on the CBR1000RR SP cylinder heads, with improved intake / exhaust flow, providing an extra 2.7 of peak horsepower. The engine has factory-matched pistons and connecting rods, to ensure optimum internal balance and maximum power.
    But don't be fooled in thinking you have Ti rods and super machined racing pistons in your SP! There the same as the outgoing bike, there just weight matched to ensure a well balanced and optimal performance, hence why such a small increase over the stock bike.
    #10 Dave dunlop, Nov 14, 2016
  11. 1000rrboyjay
    Does anyone know if the Akra system which I'm having delivered today off a 2015 blade will go on my 2008? I'll be a twat if not!
  12. Dave dunlop
    Don't see why not, I'm sure the OD port size will be the same it's just the OD of the pipes will be different. Hanging point at the rear might be out as the 2015 uses further back and higher up pegs, but if you have an adjustable band at the rear your be fine.
  13. 1000rrboyjay
    Sweet. You've calmed my nerves bud!
    I'll be selling my Akra slip on if anyone wants it!
    weer
  14. Dazzler54
    Dazzler54 Member
    I might be....let me know details
  15. 1000rrboyjay
    For 08-13 with s bend link pipe. I'll get pics when it comes off in a week. Slightest scuff to the end can. Hardly noticeable.
  16. Dazzler54
    Dazzler54 Member
    Ok mate, cheers
  17. 1000rrboyjay
    Oh yeah, it's a carbon one too. I'll get some better pics when I remove it. This is the only one I have on my iPad
  18. stupot
    stupot Active Member
    Would an Arrow can with the S Bend decat link pipe from an 08 bike fit a 2013 bike?
  19. stupot
    Just checked on the Arrow website
    Part numbers are all the same from 08 to 13, they all change from 2014>
  20. 1000rrboyjay
    Yes that should go straight on
