breaking it and listing all the parts separate These bikes are very very thin on the the ground now . The bike has a macau GP podium tomits name in 2013 and finished 4th in 2014. It’s a work of art. Lovely lovely condition. I will do my best to list the specification. The motor and electronics are fim spec. M170 ecu is fully unlocked enabling traction and full data logging with pro analysis. I have just had the bike serviced ( new motul 300xv) new standard Honda oil filter , brandnew brake fluid ( Castrol Srf) my mechanic has given it the once over and it’s had 30 Kim’s in the dyno . Specification is as follows . I’ll list it the best I can but no doubt there will be more . All numbers intact and the chassis has the vin plate so no doubt you’ll be able to get a v5 2013 CBR1000rr Full FIM WSB spec head work and cams built by Chris mahew - Pistal pistons -epoxy resin shaped head -Hrc valves and springs -mahew spec cams -quick action throttle -carbon lever guard - kit Lightweight generator and billet one off generator cover - Nova kit Gearbox - Hrc clutch - HRC duel stack carbon bellmouths - fully unlocked Motec m170 ecu (access to every rider ade possible) -motec stc -motec ltc -motec ignitors -full data logging - Motec sdl 3 digital dash with full data logging and pro analysis Motec loom with aerospace connectors - front + rear suspension telemetry potentiometers - TC Giro bank angle sensors - Front and rear speed sensors -Hrc breather and Ali Catch tank from genie -gb covers - stabilu dry break quick release fuel line -stabilu dry break rear thumb brake line - HRC quick release swimgarm -Hrc captive front wheel spindle -mwr filter -hm shifter - One off Hrc pegs - One off Alu Hrc sub frame - KTech ktr 3 SBK forks - Kit Showa magnesium shock with remote adjuster - ProMac adjustable yokes - 24L Alu fab tec under seat tank with kit boss spacer and fuel pump - large bora rad and oil cooler with quick release fittings - 17' Pvm wheels - Brembo discs all round - 25mm O/S billet clip-ons with lightech lever and span adjuster - Brembo lithium front pinless billet calipers - Brembo dual rear billet 4 piston caliper - Brembo front billet master cylinder - Brembo billet Thumb brake - lightech clutch lever - Carbonin Full Carbon fairing - CRC seat pad - HRC Carbon rear hugger - 5 button handle bar mode adjustment switch, traction control , map switch wheel speed sensors , oil temp And oil pressure , Brake pressure sensors , potiometer sensors with fuel data logging -kit linkages -blathered in titanium fastners and bolts ( bike is light as a feather ) -large arrow system -light as a feather -Ohlins damper and fitting kit -Honda racing billet fairing stays -carbon fibre clock bracket -carbon fibre dash surround -braided lines -lithium Ion battery -Honda racing battery box mounted on the generator -kit throttle bodies -kit can sensors etc -brembo res pots -rear double floating vented rota Bike finished Macau in 2014 and finished 4th Finished 3rd at Macau in 2013 Made 196 bhp at the wheel so approx 220 at the krank. Bikes running Rich above 75mph so will produce around another 10 bhp at the wheel if you wanted to lean it off For the asking price I’ll supply a brandnew set of tyres of your choice plus a spares package consisting of Front and rear Hrc subfrmaes , motec comms lead , selection of gearing , various motec sensors , spare and some other bits and pieces I also have a zero miles sp2 fireblade which may be for sale shortly I may be interested in a swap or px for something of interest ( cash either way ) Please give me a text or call with any questions 07706326464 Many thanks Daz 16k Please use the link for pictures https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/323503462598
