2017-2019 standard exhaust on track days
Discussion in 'Trackdays' started by Balrr17, Mar 16, 2021.
  1. Balrr17
    Balrr17 New Member
    Hi all
    Do any of you guys use a 2017-2019 blade on track? If so what exhaust do you use?
    I have heard the standard can is too loud for most track days, so not sure which one to purchase.
  2. PauloHRC
    PauloHRC God Like
    I'd get it tested at the local track before you throw money at a new exhsust that could be louder.
    However.......Pipewerx are quite popular for track days, I believe they do baffles that reduce noise significantly! ;)
  3. PabloPirate
    PabloPirate Active Member
    I use a MHP for quiet days, only done a couple at Donington but had no issues.
  4. dmc12
    dmc12 Well-Known Member
    My 2019 standard exhaust passed no problems at Bedford, Donington and Snetterton last year.
  5. Balrr17
    Balrr17 New Member
    Thank you for your help guys, appreciate it.
  6. Frazzle
    Frazzle Active Member
    Just remember if you do go down the Aftermarket route, Road Legal DOES NOT mean it will pass a noise test at the quieter tracks.. worth checking here and manufacturers websites for readings...
  7. NS400R
    NS400R Elite Member
    I've used the std system a couple of times at Cadwell with no issue. I believe it is the trackside sensors that can cause issues. Just find where they are and back it off slightly.
