2017 Honda oem quickshifter
Discussion in 'Mods, Upgrades, Accessories and Products' started by Stewart Lacey, May 25, 2019.
  1. Stewart Lacey
    Stewart Lacey Active Member
    Hi All
    help
    Installed a quick shifter today followed all instructions it initialised properly, turn bike off when out for a spin its no working, No up shift and no downshift then the engine warning light came on any clues anybody it’s like it’s not there
    Computer says it’s installed and on under the gears number on the dash.
    Set the level up to level 1 and down to level 1
  2. nevsrevs
    nevsrevs New Member
    I would clear any faults you got by carrying out a dtc clear using the jumper in the odb port under rear cowl. Check again. Go through all the plugs and settings and check that you got your shift rod bang on angle wise
  3. Stewart Lacey
    Update the error code is DTC 113 when I switch it all on
  4. nevsrevs
    nevsrevs New Member
    Have you cleared it and tried again?
  5. Stewart Lacey
    Been told it’s the clutch switch on the clutch levers as as fitted AVS levels the system doesn’t like iit. I’ll try the standard leavers in the morning and let all know if it works. I be amazed if a lever make a difference
  6. nigelrb
    It makes sense if the system even senses that the clutch is pulled in (due to a different casting process of the levers) the ECU will think the clutch is pulled in and will then not allow the QS to work.;)
  7. nevsrevs
    nevsrevs New Member
    True that, very sensitive with the clutch switch stopping the qs
  8. Stewart Lacey
    All sorted forgot to put the bloody little clutch switch peg on the AVS lever.
    It’s on now and all working and it’s bloody magic
    I’m a t...t
  9. nevsrevs
    nevsrevs New Member
    Just in time for a evening ride
  10. nigelrb
    See, just imagine if you didn't have the forum to help you out. :D:D
  11. Lacon
    Lacon New Member
    Stewart - glad you got it sorted.
    Out of interest, how easy was it to install and how much is the unit on its own?
    I’ve got a 2018 blade in January but just couldn’t stretch to getting the QS fitted as well (London insurance premiums..) but would like to get one in a couple months.
    Thanks
    Andy
  12. Stewart Lacey
    Very easy to install, and works great now I’ve sorted the clutch switch issue which was my fault. If you have standard levels it won’t be a problem. Get one it changes the bike goes though the greats like knife though butter.
    Don’t forget you need to put the ECU in learn mode, that’s what I call it
    Video on YouTube
  13. nigelrb
    Huh?
    Are you saying that you'd be charged a higher premium just because of a quick shifter?
    If anything, it should be a lower premium because their is not rider attention diversion to the clutch operation. Well, that's what I'd be replying with!!:)
  14. Lacon
    Lacon New Member
    I’m sure they would charge more but meant that my insurance is so high living in London (despite a tracker and keeping it in a garage!) that I couldn’t afford the £650 odd for a snifter when I bought it
  15. Manny
    Manny Active Member
    HI do you have the instructions and also the link on how to put the ecu in learn mode
  16. stelwalker
    stelwalker Active Member
  17. PabloPirate
    PabloPirate Active Member
    Ten-Kate are doing this cheap at the moment.
