2017 SC77 dash quickshifter help
Discussion in 'Mods, Upgrades, Accessories and Products' started by Scottmurray2890, Dec 30, 2021.
  1. Scottmurray2890
    Scottmurray2890 Active Member
    Bought an hm oem shifter/blipper
    Plugged into OEM harness, put on dealer plug,into settings and in cant get into quickshifter menu to activate it, just stays greyed out.
    Anyone any ideas.
  2. Scottmurray2890
    Figured it out cheers
  3. Coda
    Coda Active Member
    What was it? In case someone else comes across the same problem.
  4. Scottmurray2890
    Me not reading instructions properly. When you go into the dash menu there's an option for quickshifter which will be greyed out. You've got to go to service/maintenance first,then quickshifter, activate it, intialize it. Then the original quickshifter menu will he available.
    Same goes for suspension of you were ever to add on the adaptive which I doubt anyone will.
  5. Scottmurray2890
  6. karl wesley
    karl wesley Active Member
    the shifter/blipper is so much fun,Best fun upgrade ever
