A better battery...
Discussion in 'General 1000RR Discussion' started by Patriotk11, Apr 6, 2025.
  1. Patriotk11
    Patriotk11 New Member
    Hi
    I have a 2010 which I'm sure doesn't have ABS but the battery last season was not great. Slow starting, or flat if left for a day or two.
    I've trickle charged it all winter but it's no good.
    Can anyone recommend an uprated battery or at least one with a better start voltage or CCM.
    Thank you
  2. Lock
    Lock Active Member
    Noco lithium - seems good for me
  3. Boothman
    Boothman Elite Member
    This is still going strong after 6 years
  4. Broadie
    Broadie Active Member
    Odyssey
  5. bonjo
    bonjo Active Member
    two options worth considering:
    good value AGM with 120CCA minimum and plan of replacing it every 2 years like a routine maintenance. Don't waste your money on yuasa.
    Alternatively an LFP battery. The ones recommended all have very small capacity, typically 2~3 Ah which is ok if you don't have parasitic drain or are patient with starting in cold temps (<3deg)
  6. Patriotk11
    I've gone rogue.... I've tried a Poweroad with the following spec
    New Factory Sealed Nano Gel Technology Batteries
    3 Year Warranty
    Technical Specification
    Voltage 12 Volts
    CCA 180A
    Length 113 mm
    Width 69 mm
    Height 105 mm
