Abba stand sky lift
Discussion in 'Mods, Upgrades, Accessories and Products' started by martinowen, Feb 11, 2014.
  1. martinowen
  2. Dave V
    Dave V Elite Member
    See it in action at the NEC- On our list for the cave.
    Ramps awesome, but doesn't lift the wheels off the ground/ramp- This will fill the GAP.
    #2 Dave V, Feb 11, 2014
  3. martinowen
    I missed it at NEC, its not cheap but looks worth it.
    Will see if its at the excel on the weekend
  4. lambchops
    lambchops Elite Member
    dont think its too bad for the money when you look at some of the basic hydrolic ramps will set you back that much.. Looks good :)
  5. Remal
    I'm more impressed with it the more I see it
    And martin posting this thread in the lounge tut tut. ;)
  6. martinowen
    Oops
  7. Dave V
    Dave V Elite Member
    Just watched the vid again. That's alot of pumping to get it up!
  8. martinowen
    Yea I thought that Dave, almost need a longer lever it seems
  9. Dave V
    Dave V Elite Member
    Think you could be right Nav, although could be hydraulic fluid tank that needs to be bigger?
  10. martinowen
    Yea true
  11. sps170373
    Isn't this just a slightly fancier version of the warrior bike lift? I know you can angle the bike with this but if that's the only extra!
  12. Repsol Rob
    Repsol Rob Elite Member
    The Warrior lift does nt lift bike to anywhere near as high................
  13. martinowen
    I have a lift the same as the warrior it's good but not this good :D
  14. ShinySideUp
    ShinySideUp Elite Member
    The warrior lift only lifts from one side and takes bike up a few inches off the ground front n back whereas the skylift is basically an abba sportsbike stand with front arm lift built onto a hydraulic piston lift rig.
    The skylift uses the same bike specific adapters as the abba stand too which locks into the swing arm pivot (canny think or engine mounting point) on both sides so bike cant fall off the stand like it could the warrior type!
    I have gathered quite an array of stands in the few short years of owning bikes including and abba stand now with front arm lift add on, twin alloy paddock stands, rear steel tube paddock, front headstock tube stand and a hydraulic ramp lift!
    Each have there uses but if I am honest if I had known how much I would have spend on stands at the beginning I would have stumped up the £400 odd for the skylift first and be done with it! ;)
  15. martinowen
    I would just park it up in the wheelie position, what a sight when you open the garage door :D
  16. Dave V
    Dave V Elite Member
    Sure that's the best idea with your luck Mart?
    Would look awesome though
  17. ShinySideUp
    Haha that's what was just goin through my head when I read that!
    With my luck I would prob park the bike up in a position without thinking and end up skelping the bike with the garage door! :D
  18. N_Collins
    N_Collins Active Member
    I got one from the NEC and it's the best lift I've seen just got to get my brothers ZX10R off it!!
    The best bit is you can move it around really easily!
  19. martinowen
    Is it cheaper at the show?
  20. sinewave
    The trouble with any of these type of lifts is they flex about a lot when working on the bike.
