ABS removal
Discussion in 'Mods, Upgrades, Accessories and Products' started by RepsolPaul, Jan 6, 2015.
  1. RepsolPaul
    RepsolPaul Well-Known Member
    Going to remove the ABS system for racing, anyone know of any problems I'm going to run into?
    Also, someone mentioned a tilt switch that has to be removed for racing also ??
    Any ideas?
    Cheers in advance.
  2. ColinBR
    Can't see any problems with removing the ABS system. I'm also doing the same in the next week or 2.
  3. wedgiewolves#223
    wedgiewolves#223 God Like
    No tilt sensor has to stop well it doesnt but when its on its side (hopefully it doesnt) you will want it too cut out just buy a race bracket tilt sensor bolts to front . Side stand switch and if remove left hand control switches this will remove the clutch switch
    HONDA CBR 1000 RR (2008-2015) RACE FAIRING BRACKET | eBay
  4. scooby
    scooby Elite Member
    well,and this is only from being told,not through experience.i'm not sure it can be done without throwing up problems.only reason I know is my m8 bought 1 to race and you couldn't re configure the lines to pass scrutineering,or remove the ABS system without electrical issues.i don't thinjk it's just a case of removing the plumbing and pump etc.like on the BMW.
    he sold his bike soon after for a non ABS model.
    have you looked into how to do it?
  5. ColinBR
    It can be done mate.
    It's is simply a case if removing all the plumbing and then the ABS ECU as it is a stand alone system.
  6. ColinBR
    Also how could he not configure the lines?
    All you have to do is fit standard lines in the conventional way.
  7. scooby
    scooby Elite Member
    like I said I don't know,I'm only going off what I've been told. the lines in ABS config. don't meet ACU regs that's all I know.
    'but if it's as easy as that then fair do's.
  8. graemewalker
    graemewalker Elite Member
    Colin is right I done mine to the 600 last year back to conventional brakes and no issues at all like he says new braided lines abs pump and module out and unplugged,honda said to me it would not work but they would say that to cover themselves, image.jpg image.jpg image.jpg you can just make out where I removed it image.jpg
    I have to say I left a pipe behind rear master cylinder as I could no way get it out without removing engine but was disconnected image.jpg
    #8 graemewalker, Jan 6, 2015
  9. graemewalker
    image.jpg back to standard front and back from a brand new abs 600 RR freighting I know but t image.jpg urned out well image.jpg swingin arm off now on its way to lester at harris for conversion will post a pic when job complete
  10. graemewalker
    Bollocks to abs I have had 2 blades both abs and they were s..t I have to say hense why I bought a sp blade non abs ,u would have to pay me the £600 quid to get one not the other way round,honda needs to shape up and move the blade on as they are lagging behind the likes of bm and Kwak ,yam ,yes brilliant reliability but have to progress with tc and the likes
  11. scooby
    scooby Elite Member
    now you've done it...:)
  12. Mad Matt
    Well the reason i swapped my Blade for the zx10 was the abs, i was informed buy 2 separate dealers and Honda UK that the abs couldn't be removed..
    Will be interesting to see the outcome...
  13. graemewalker
    Like I said Matt I have already done it can't see what the problem all u peeps have about it not a big deal simple conversion
  14. Mad Matt
    I should have bought it round to you mate, might of kept the Blade if i knew it was possible, could it be that the 600 is different to the 1000??
  15. graemewalker
    No different as Colin said remove all lines abs ecu and pump job done it's as col said stand alone
  16. RepsolPaul
    The bike is a CBR650F, brand new, seems different as doesn't seem to a separate ECU, just one on the end of the pump and loom is in with the main loom.
    Started to take apart today and Finish tomorrow and order new braided lines.
    Cheers guys, everyone to the rescue with information, so love this forum.
  17. ShinySideUp
    ShinySideUp Elite Member
    There are only two model that utilise hondas combined abs system and that's the cbr1000rr and the cbr600rr's.
    Most other models utilise a Bosch abs system which does not use the brake by wire system that's plagued the inferior blade system.
  18. sinewave
    That may be true Mat but you also got superior Power and Handling, a sweeter gearbox, TC etc and that warm fuzzy feeling that you're riding the same bike as Shakey! [​IMG]
  19. Jimbo Vills
    Until he crashes it and it breaks into a million pieces! :eek:
  20. RepsolPaul
    Yes, when stripping it down we was joking about beating him to it and just denting the tank now as it going to happen for sure.
