Another problem...
Discussion in 'Maintenance' started by Mr OCD, Jul 12, 2017.
  1. Mr OCD
    Mr OCD Well-Known Member
    No didn't replace chain.
    If it was a valve it would get noisier on revving?
  2. Spartan Andy
    Spartan Andy Active Member
    Comparing the first video before the CCT was changed, The noise now has changed.
    My thoughts now it that the new CCT has taken most of the slack out of the timing chain but not enough.
    Not to lead up the wrong path just based on videos, But could this noise be the actual timing chain stretched?
  3. Mr OCD
    I agree ... it sounds as though it has improved but not enough ... when I took the old CCT out I couldn't remove the centre bolt so was expecting to adjust out fully and push the other two bolts as I loosened - it didn't so I'm wondering if it was fully extended?
    Is this possible?
    If it needs a new timing chain I assume it's a cams out job. If that's the case I'll get KAIS to do it and also check valves whilst they are there.
    Before I do anything I'm going to seek another opinion.
  4. TheRamJam
    TheRamJam Well-Known Member
    So how did you fit it mate. Did you rotate the crank to TDC or just fit it as as?
    I was going to fit a manual CCT to my RR9 but am a bit nervous of removing the OE ACCT and then the cam chain jumps.
  5. Mr OCD
    Pop timing cover off and rotate to TDC.
    Install new CCT and then pull locking pin ... as a safety check I then rotated crank a couple times by hand to check all is well.
    Cam chain won't jump - there isn't enough space in the cases for the chain to jump.
  6. roboticus
    roboticus Active Member
    I'm going kais next few days if u need a lift in my van. I'm in Bolton. :)
  7. Mr OCD
    I'm in Bolton as well!
    When are you going? I was planning to drop it off tomorrow. But would rather not ride it unless have too!
  8. roboticus
    Will it fit on the roofrack?
  9. graemewalker
    graemewalker Elite Member
    If you change cct always best to change chain as it will be stretched with those amount of miles boss tell Jonny I am asking after him
  10. Mr OCD
    Well it's been dropped off with KAIS suspension to investigate further as I simply don't have the time to investigate further and after covering the basics it's time to let the pros sort it ...
    Thanks to @roboticus for kindly giving me a lift in his van to drop the bike off.
    Fingers crossed it's nothing serious.
  11. roboticus
    Your welcome. Anytime mate.Fingers crossed we don't have pick it up in the van.
  12. roboticus
    U forgot to list it might be the 2p u dropped down there last week.
    Sorry is it to early for jokes?
  13. Mr OCD
    I'm going off you ... :p
  14. roboticus
    1st on your brakes :rolleyes:
  15. Mr OCD
    :D
    I'll be taking them to the next bike when it's time to trade the blade ... ;)
  16. roboticus
    Is that good?
  17. Mr OCD
    Yep. Easy fix :)
  18. roboticus
    Dam. Haha only joking. Let us know if u need me mate
  19. roboticus
    You'll be lucky. U not know there busy!!
