Just as the title says. Power Commander 5. Its the 16-034 which means its designed for the 2012 - 2016 bikes primarily but will fit the 08 - 11 perfectly. The unit accepts both types of fuel map. The PCV for the 08-11 had a different Fi sub loom and the PCV plugged into the TPS and the outer injectors directly. The inner two injectors were on the same sub loom. This 16-034 unit plugs directly into the 4 separate injectors. No issues at all. As you can see its in excellent condition and comes boxed with all the accessories including 1. Power Commander 16-034 2. Software on CD 3. O2 sensor eliminator 4. Full instructions. 5. USB cable 6. Stickers and velcro mounts. I have loads of customer maps available. Just tell me what year your blade is and what exhaust you have and I will do the rest. Looking £165. UK post is £7. Euro zone £15 Barry. 07921 849 076.
Out of interest, can these be fitted with the Translogic QS? ...I mean that they use the same connections, no?
two completely different applications. the translogic plugs into the coils. The power commander into the fuel injectors. two completely different systems which work alongside without any issue.
