CBR1000RR-R idle speed
Discussion in 'General 1000RR Discussion' started by dgr, Jul 5, 2022.
  1. dgr
    dgr Active Member
    Does anyone know what the correct idle speed is for the RR-R when warm? My SC77 used to sit around 1200 but this one seems to settle at 1400 +/- 50, which seems a little high.
  2. Jay Floyd
    Jay Floyd Active Member
    TBH i haven't really noticed..... but i will take a look later today buddy.
  3. Jez
    Jez Senior Member
    mine is 2014 and its about 1400, at times I do think it is a little high
  4. bonjo
    bonjo Active Member
    Let us know if you ever get to the bottom of this.
    does honda say 1200 +/-100?
  5. dgr
    dgr Active Member
    Will do. For the SC77 it is 1200 +/- 100, not sure about the SC82. I'm trying to get hold of a service manual.
  6. bladey
    bladey Senior Member
    Mines about 1250. SC77.
  7. Fatboy
    Fatboy Active Member
    SC82 is 1400 +/- 100
  8. dgr
    dgr Active Member
    Thanks, is that from the service manual?
  9. Fatboy
    It certainly is matey :D
  10. Jay Floyd
    Mine is on average 1400 RPM..... and that's after a run. it fluctuates between 1390 and 1410 rpm :)
  11. dgr
    dgr Active Member
    That's what it should be according to the service manual, so I guess they set the idle speed higher than on the SC77.
  12. Jay Floyd
    I wouldn't worry about it bud, seems fine and the same as mine :)
  13. Gas gas
    Gas gas New Member
    Hi did you ever resolve your high idle, I've just fitted ackropovich end can which specified no remap and now idles at 2k which is no good because this causes blipper to not work correctly due to throttle not being off thanks
  14. dgr
    dgr Active Member
    The idle speed is set higher on the SC82 than the SC77. Mine was in the correct range of 1400 +-50. 2000 is way too high if the bike has wamed up properly, so something is off. Just changing the end can shouldn't have that effect so I'd get it looked at if I were you. I had a high idle problem on another bike that was fixed by a full ecu reset. Did you fit a servo eliminator when you changed the exhaust?
  15. Gas gas
    Gas gas New Member
    It came with a blanking plate for the servo, I was going to try a servo incase this was better for electronics
  16. dgr
    dgr Active Member
    I removed the exhaust servo motor completely and used a Healtech servo eliminator.
  17. Gas gas
    Gas gas New Member
    Hi mate thanks for the reply, I think I will try an eliminator first b4 I go down the dyno route my 2018 blade had no valve but had been dynoed with Yoshi and ran perfect this is horrible won't blip down due to the high revs I think, was perfect b4. I have been told that all the servo buddy does is keep the engine light off
