Cleaning Product Recommendations
Discussion in 'Maintenance' started by Jae, Oct 3, 2018.
  1. Jae
    Jae Active Member
    Hi all,
    Just wanted to know what would be the best cleaning product for aftermarket titanium headers? WD40 helps, but I need something a bit more potent.
    Thank you
  2. tuktuk
    tuktuk Elite Member
    Not much help at this stage but since installing mine every so often i wipe it all down with brake cleaner.
    You can have them blasted and they come out pretty much new. Sonic blasting I think it's called?
  3. Jae
    Jae Active Member
    Thank you. I'm yet to use brake cleaner, but I know that stuff general works well. There seems to be some rust and finger prints burnt in, hoping to freshen the headers up before fitting.
  4. Gaffa22
    Gaffa22 Well-Known Member
  5. lardytkd
    lardytkd Active Member
    Harpic works a treat. I know loads of people that swear by it. I've seen pics of before and after and hey look amazing.
  6. Gaffa22
    Yes i've been using for quite a while its quick and easy
  7. travellingkiwi
    travellingkiwi Active Member
    Puddles mate... Ride through enough and it'll take the mud off no probs...
    • Funny Funny x 2
  8. Jae
    Jae Active Member
    So, I ended up using harpic cleaner which help a bit but to get the deep markings off, Autosol is godlike. It took a lot of elbow grease but was definitely worth it in the end. The originally colour was a light shade of gold but that all disappeared afterwards. Sorry for the photo bomb.
  9. Jae
    Jae Active Member
    Final results :D Not sure if it'll burn in now that it's polish, thought it does look a lot better than before.
  10. Gaffa22
    Good job Jae they look great
  11. nigelrb
    That is friggin' brilliant @Jae . I've never used Autosol but will be sure to get some now!!
    Back to the original question though: surely they're not titanium headers? I would have expected a dull finish. The headers appear to be polished mild steel. Are you sure they're titanium?
  12. Jae
    Jae Active Member
    Thanks mate, they should be going on this week.
    Thank you. I'm not a big fan of chrome in general but I am more now.
    I was expecting the same finish too, more like a flat matte silver. I bought this from a mate and he told me it was a titanium exhaust imported from the US. I noticed some burn in rainbow marks near the flange but this is now buffed out.
    Now I've tested the pipe with different types of magnets and the thin flat ones stick in certain areas whereas general fat magnets don't stick -I guess you could say it's temperamental. This got me confused, so I did some research and found out that titanium is actually weakly magnetic.
    REF: http://www.rexmetals.com/is-titanium-alloy-magnetic
    I'm guessing titanium comes in different types of materials, finishes or I could be complete be wrong. I'll be fitting the exhaust later this week so hopefully I'll get more clarity. I could always shoot Yoshimura an email with the part # and maybe that'll help too, but regardless I'm super excited to fit this baby on
  13. hitch
    hitch Elite Member
    They look awesome.
    This really scratches my OCD clean itch o_O
  14. Spygoat
    Spygoat Well-Known Member
    You'd not be able to polish out the bluing/rainbow effect on titanium. Those look to either be ceramic coated or stainless. I would actually lean more towards ceramic coated steel, which is a very nice option as it keeps the temps down and can polish out brilliantly. I also lean towards ceramic coated because of your magnetic testing. Depending on the thickness of the coating, magnets may not stick as well in some areas.
  15. Jae
    Jae Active Member
    Update. Finally fitted the exhaust which was a bit of pain aligning the flanges. Just picked up a M16>M12 reducer for the O2 sensor and she should be ready quite soon.
  16. Boothman
    Boothman Elite Member
  17. vic_ster51
    vic_ster51 Active Member
    I think you will find jae they are stainless for sure. You wouldnt get that finish like others said.
    Yoshi never done a ti system (headers) either for the blade. Well not 1 that they sell to general public.
    100% stainless my friend. You should be able to tell from weight. Or cut it Haha it will spark white :p
  18. nigelrb
    Those pipes look magnificent. I am blushing with shame after thinking my 'Harpic job' was the bees knees:(.
  19. Jae
    Jae Active Member
    Thanks all.
    Just got a reply from Yoshimura and they have advised the headers are definitely stainless steel :)
