Clear stick on boot guards
Discussion in 'Wanted' started by Boothman, Aug 15, 2018.
  1. Boothman
    Boothman Elite Member
    #1 Boothman, Aug 15, 2018
  2. roboticus
    roboticus Active Member
  3. Boothman
    #3 Boothman, Aug 15, 2018
  4. roboticus
    haha, I need get some for mine, im ok i'v a black frame tho, I've used insulation tape being from bolton
  5. Blade runner 1
    Blade runner 1 Elite Member
    You could always get some paint protection film and cut it to the correct shape/size
  6. Boothman
    #6 Boothman, Aug 15, 2018
  7. Old_boy65
    Old_boy65 Active Member
    Sellotape... Quick/easy option
    Sticky backed film... Slightly more of a faff​
  8. Boothman
    #8 Boothman, Aug 15, 2018
  9. hitch
    hitch Elite Member
    :eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek:
  10. Barstewardsquad
    Look at Mr Branded Accessories. Just go to Wilko/Poundshop and get a no-name roll :p
    • Funny Funny x 2
  11. bradt
    bradt Elite Member
    Not sure if the paint protection Ventureshield would stick but worth a go.
  12. Boothman
    #12 Boothman, Aug 15, 2018
  13. Old_boy65
    QUOTE="Repsol Ron, post: 466671, member: 6714"]Fair point Old_boy65 - beginning to think I’m worrying for nothing[/QUOTE]
    ... I’m thinking a crafted piece of venture Sheila might be a good call... :)
  14. Blade runner 1
    Stuck a piece of paint protection film on my rear sets heel plates over a year ago and it’s still hanging on, a couple of quid from ebay if it doesn’t work on the frame you won’t have lost much. Maybe give it a go on mine tomorrow just out of curiosity.
  15. Blade runner 1
    Ok tryed a sample on the frame from a little off cut that was lying around, you can obviously make it as big or small as you like. Sticks to the frame no problem, if you go down this route just make sure you clean the surface probably. AF16E64D-16DE-4E1F-A806-FB6A9D2E6773.jpeg
  16. Boothman
    #16 Boothman, Aug 16, 2018
  17. Ian E
    Ian E Active Member
  18. Boothman
    #18 Boothman, Aug 16, 2018
  19. Blade runner 1
    That would certainly do the job probably better quality than I have. Think this is what I got.
    https://www.ebay.co.uk/itm/RHINO-HI...hash=item3f593a62b9:m:mGAVP3z01dBGBixTH-m2ClA
    It has a backing film and gloss side protection film to protect from scratching whilst squeegying during installation.
    Fairly easy to apply, Clean the surface I use isopropyl alcohol, make a solution of water with a couple of drops of washing up liquid in a small spray bottle, spray surface which your applying to, remove backing film (you'll know when you've removed the backing film as the surface of the tape will be slightly sticky, try a sample piece first). Spray film with solution and apply it to your frame, you should then be able to slide it into position, squeegee out the excess solution and let it dry. If any corners don't stick immediately put pressure on it with your finger for a minute or so, remove protection film. If you think you can apply it without sliding into place you can just use water, the washing up liquid is just to make it slide. Plenty info on youtube.
  20. nigelrb
    Both of you are bang on. I have used PVC Book Cover for some time now. I started using it as protection from stones on the front edge of the fairing belly pan, but have since made templates for tank protection from knee rub. (I am not a fan of the Stomp Grips etc.)
    Book cover is a manageable film if used with care and patience. The pic here is my 2018 tank. The film is precisely cut to fit within the edges of the blue. Even if you save and enlarge the pic you will not even notice it. Whether or not it will turn yellow I seriously doubt, as this bike rarely sees sun!:rolleyes:
