Cutting out whilst riding
Discussion in 'General 1000RR Discussion' started by Deano1988, Sep 20, 2022.
  1. Deano1988
    Deano1988 New Member
    Hi people.
    I have brought a 07 1000rr all was fine until the other day whilst i was riding the bike seems to loose all power with the oil light and the hiss light showing then the power will kick back in. This happens at any speed and under normal acceleration. Thanks
  2. Wes
    Wes Active Member
    Do you have any stalling issues mate ? When the power cuts is it for a split second and then she continues to run as normal ?
  3. Deano1988
    Hi pal its only for seconds then runs normal again without any stalling isssues. I covered over a hundred miles on sunday without one issue then went on it monday and it started playing up.
  4. Marc
    Marc Active Member
    My RR6 did the same earlier this year. Not sure on the right terminology but it was the metal bit you attach either the positive or neutral to, it had snapped inside the battery itself. You could pull the whole thing out, so the bike kept cutting in and out. Left me stranded for 7 hours in the Dales, thanks to the utterly useless AA.
    Replacement battery sorted mine.
  5. Deano1988
    Thank you ill have a go at doing that if i dont get it sorted before payday hopefully its a cheap and quick fix
  6. Saqib
    Saqib Active Member
    A broken electrical connection is likely the best place to look first I guess. Check all the fuses and wiring to see if anything is broken or corroded.
    Could have dirt in the fuel tank causing blockages, so don't rule this out.
  7. TomLum
    TomLum Active Member
    I had this issue with my 07 when I had incorrectly re-fitted the tilt sensor in the nose. Certain riding conditions was enough to trigger and cut out with the same symptoms. Mounted it correctly and it sorted it
  8. Deano1988
    I can move the positive terminal so it looks like its a new battery
  9. Marc
    Marc Active Member
    If you switch the ignition on and wiggle the terminal that should tell you for sure. It’ll cut on and off if that is the source, as per mine.
    Conscious that the diagnosis suggested may need a health and safety warning with it, so wear rubber wellies and try not to use your tongue to wiggle the terminal.
    • Funny Funny x 2
  10. Dan Tyas
    Dan Tyas New Member
    Bit late to this conversation but I had this exact issue whilst out riding yesterday. Just after a bit of hard acceleration and the nrolled off the HISS light and Oil light both came on for a few seconds and the bike cut out (was still in gear and it didn't lock the back wheel, this is my main concern of when it happens) the bike then came back on and was fine.
    Im going to have a look around the battery today and see if i can use the above to sort it, might be time for a new battery though by the sounds of things.
    (2006 CBR1000RR)
