Hi all, Bike is running fine but it has been 2 years since it was last set up on the dyno. I was wondering if once set up they need re-doing now and again. Not made any changes to system ie same PC and exhaust system etc which would obviously require a new set up. I get everything else maintained/checked so wondered if it was something I should consider. Thanks in advance.
I think it can change slightly as obviously parts ware etc but only slightly so if there isn't anything obvious I would leave it
Thanks Martin, I just wondered if there is a period when it becomes not as good as it could be. Bike is running great atm so will leave it as you suggest.
I'm only taking a guess to be honest mate, if you were racing I would say maybe do once or twice a year as every pony counts plus it has a hard life. On the road unless you have added something or there is a problem I wouldn't worry. You could always just go for a power run and see if its lost much, what's that 30 quid?
Agree with above, unless your bike is a track bike then i can see no point, indeed having the bike running just fine but still going for a Dyno would seem a waste of money and time..... it is after all a road bike that is running great.... if it ain't broke .... you know the rest.
