I have adjusted fuel mix on a run and got EML light on, I have since put fuel back but the dash light says on, How does it reset. I dont know what fueling map it uses when light is on but runs better than before,
You could try an ECU reset. Details are on here somewhere but it is basically leave battery unplugged, start with no throttle, don't touch anything, when fan kicks in stop with kill switch.
It is probably worth a go on the ecu reset, I did a reset when I fitted the racefit end can so the ecu can learn a new fuel map, I will have to get a pcv over winter.
before it reset it was flashing, if you count the flashes between the slight pause you can then look on the internet and find the cause. mine was 9 flashes, air intake sensor fault
When my exhaust servo eliminator went bad, I got error code 35. The slow blinks are factors of 10 and the fast blinks are factors of 1. So, for me, three slow blinks and 5 fast blinks. Glad you got it sorted. My bike goes into a limited power mode when the EML kicks on.
