Hi out there, bit of a Q for you all. The 929 and 954 hix valves open at 3000rpm and 7000rpm. now! the servos are the same except part number. People tell me they are interchangeable. On the 929 servo it has MS104 on the 954 it has MS104A printed in white on the servos. The 2004 fireblade is identical servo but with MS104B, would this servo fit a 954?? The 929 and 954 on the hix has 90 degrees 0 degrees and 180 degrees. at 3000 it goes to 0 and 7000 to 180. would a 2004 blades servo do the same? it is the ecu which tells the motor to operate at 3000 and 7000. The cbr1000s open at 5600rpm so ive read, but is it the same as the 929 and 954 ie 90 0 and 180?? basically will a 2004 servo work in a 954?
