GI Pro gear indicator Reset Problem
Discussion in 'Maintenance' started by bradt, Apr 21, 2014.
  1. bradt
    bradt Elite Member
    Hi all I need some help !
    I have not been able to reset the GI gear indicator fitted to my RR9.
    I have downloaded a copy of the user guide (it states the following)
    1) Turn the ignition key on and then immediately turn off while the GI pro is counting up and showing 3, 4 or 5
    2) Repeat this 5 times
    3) On the next power up the display will count backwards (6 to 1) and the memory is cleared and the unit displays a 'flashing L' and then reset
    I am following the user guide but cant get a 'flashing L' so unable to complete a full reset: mad:
    Any ideas ?
  2. Mike07
    Mike07 Active Member
    Does it give a slightly different sequence for a Gipro that has been set before.... Maybe someone's been messing with it. Also when I did mine I had to do it a couple of times to get it right.
    Good Luck,
    Mike.
    Sorry after reading your post again you are rs-setting it. Well I used the kill switch, was easier than the key, but still took a few attempts.
    #2 Mike07, Apr 21, 2014
  3. bradt
    bradt Elite Member
    Sorted it :D
    Cheers Mike for your reply..
  4. Colum
    Colum New Member
    My bike came with a GiPro indicator needs resetting. No manual. What to do after getting a flashing L, if I get a flashing L))
  5. bradt
    bradt Elite Member
    Hope this helps
  6. Colum
    Colum New Member
    Thanks bradt, I have it set now)) In my enthusiasm I made the mistake of setting it on a winding country road)) was in 6th gear around the bends waiting for the GiPro to learn the gear))
