header removal
Discussion in 'Maintenance' started by keithg1748, Jan 30, 2021.
  1. keithg1748
    keithg1748 Active Member
    hi i have just removed the headers off a 2017 sp to cut the cat out and (hopefully) fit a link pipe to fit the austin gp1r can , so the bikes done about 4000 ish miles so would you replace the gaskets or will thy still be ok , thanks .
  2. Iain
    Iain Active Member
    New gaskets, and consider new studs and nuts whilst you are at it.
  3. keithg1748
    cheers. , and i will have a look .
  4. keithg1748
    ffs, any idea how you can remove the old header gaskets , these are a pain and cant get them out , cheers
  5. Iain
    Iain Active Member
    This may help, although if they are still in good condition, some say just leave them in.
    Exhaust Gasket Removal | Honda CBR 1000RR Forums
  6. keithg1748
    i did buy some oem new ones and took them out the bags , so i cant take them back , lol
  7. keithg1748
    Hi can someone tell me what i could put on the gaskets to hold them in place while i fit the headers ? and is there a certain way the gaskets go in the head as there seems to be a bit of a seam on one side , thanks for any advice.
  8. tuktuk
    tuktuk Elite Member
    Little smear of general purpose grease should help keep them in place if they wont sit by themselves.
  9. keithg1748
    cheers , did it and all done now , just need to wait for a dry day ( as the missis might say summat if i start it up in house , lol ) to fire it up and hope theres no leaks anywhere , fingers grossed .
  10. keithg1748
    there it is .
  11. Trav_1981
    Trav_1981 Member
    Looking good. Will you post a pic when fairings back on so can see the whole bike? I’m undecided what to get yet but this is most likely.
  12. keithg1748
    will do mate .
  13. keithg1748
    heres one for yer , lol
  14. Trav_1981
    Trav_1981 Member
    Looking good. Are you happy with it?
  15. Herbert J. tea3agger
    Herbert J. tea3agger Active Member
    I got an Austin Racing slipon on my 2017.
    I still have the cat though.
    Leave the cat cos the fkr will be too loud otherwise for the road - My Austin has the baffle in all the time and is at a reasonable noise level :)
  16. keithg1748
    i have both baffles in now, as i took the middle one out and is was way too loud , but its not that bad now , lol
  17. Herbert J. tea3agger
    My Austin Racing slipon was actually from my 2016 - I had an adapter and hanger made so it fits the 2017
