heal tech servo eliminator
Discussion in 'Mods, Upgrades, Accessories and Products' started by Gshock, Jun 17, 2018.
  1. Gshock
    Gshock Active Member
    Just fitted an arrow end can to my 17 blade. fitted the servo eliminator to, however still have the engine light on? the packaging says if this is the case I should go for 3 short rides to cure this? Anyone had the same?
  2. Alan-lee
    Alan-lee Active Member
    No it worked first time for me just plugged in and away I went!
    I assume you haven’t went for a wee run to see if it clears up?
  3. Hashlak
    Hashlak New Member
    I have this issue also.. Engine light is on but no codes..
    Just got used to it now lol
  4. nigelrb
    Ah, there's a lot to be said for leaving a bike standard!
    (I hope no-one picks up on the fact that my 2011 has Yoshi R77, Bad Dog levers, HEL lines, carbon hugger, gear indicator . . .:rolleyes:)
  5. hitch
    hitch Elite Member
    If the three rides fail to sort it, rip it out and send it back for a refund.
  6. Alan-lee
    For those that have lights on id be sending them a message for a replacement. The whole point of it is that it’s supposed to keep the light off
  7. Alan-lee
    This
  8. dgr
    dgr Active Member
    The exhaust servo can be turned off in the ECU using the Woolich software. That's why I don't need the servo eliminator I bought anymore. I'm surprised yours wasn't turned off when you had your bike mapped.
  9. keithg1748
    keithg1748 Active Member
    do you still have the receipt in case it doesn't work so it can go back , lol
  10. dgr
    dgr Active Member
    If it doesn't work send it back to me. I'm not sure I have the receipt but I'll get in touch with them. It worked for me though. At least, I never saw the warning light.
  11. Gshock
    Ive put the servo back in and now theres no light
  12. Hashlak
    Hashlak New Member
    Did you just remove it and put it back and that fixed the issue..?
    If so I shall give it a shot..
