I did it - Bought a Power Commander & Air Filters
Discussion in 'Mods, Upgrades, Accessories and Products' started by samuk, Sep 14, 2012.
  1. samuk
    samuk Well-Known Member
    Just paid for a Power Commander - Will be with me tommrow..
    Cant wait to see the difference - initially will use a pre-set map but later may get a custom map put on.
    Also go K&N Filters coming tomorrow to go in... :D
    I love it when me and the wife argue - it brings me and the blade closer :D.
    Glad it ended with this as i was about to buy a newer blade! lol
  2. robinh73
    robinh73 Well-Known Member
    Nice one, well worth it! I did the same and ended up having a custom map just to smooth it out as it was running rich at the lower rpm range. Get a custom map done, it doesn't cost the earth and you get to see the magic numbers from the dyno too!!
  3. samuk
    I shoulda actually gone on the dyno when the bike was standard..
    We're did you get you map done from? You did tell me once but I forget the name of the place?
  4. robinh73
    I went to Moto Corse Racing in Wrexham, so not exactly around the corner for you! But that said, the guy knows his stuff. All I would say is don't listen to the torture that goes on in the dyno room!!
  5. samuk
    right, opend the bike up, cant believe how easy it is to fit!
    just not sure about the TPS - Throttle Position Sensor connector.
    The instructions i have say:
    Behind the left upper fairing, behind the rectifier, slightly to the right - The plug comes off downwards...
    anyone know if i need to take the upper left panel off to connect this?
    #5 samuk, Sep 15, 2012
  6. JM1
    JM1 Active Member
    You just need to lift the tank
  7. samuk
    All sorted --- i have also downloaded the software from Dynojets site..
    I cant seem to find any default maps anywhere..
    any idea's?
    Sam
  8. ray
    ray Well-Known Member
    Sam,
    Did you download all the maps from Dynojet's website as well as the software?
  9. samuk
    I found the maps.
    I downloaded the PC III USB Control Center Software - and uploaded the map Apraprovic Full exhaust with aftermarket filter - i think that's what it was called..
    Whats the PCIII USB Accelerator Pump Enable - this comes up with an error when i run it..
  10. ray
    You lost me on that one mate.
    You're best off asking Arthur as he is a mindful of information.
  11. Haggler ®™
    Haggler ®™ Active Member
    I cant remember how you set it but when you do get it to work start off with about 60% and work upwards.
    It enables a little bit more squirt when operating the throttle,only works for about 50 rpm but you,ll feel the difference.
  12. samuk
    Right...just went for a ride..and that 1st gear scared the hell out of me! think i shall take it easy for a wee while!
    K&N's have changed the sound of the engine, flapper mod also helped..bikes ALLOT smoother through out the rev range, not that i really pushed it too hard on the first run..but did get on the motorway... Love it! even more worried about the braking power now...
    Took about 4 hours - as i took my time - and enjoyed the install...
    So pics:
    Fuel Pump is enabled, but not sure how to set this - any help appreciated...
  13. ray
    Here's your next mod Sam,
    Gutting the Intake :D:
  14. samuk
    hmm.. benefit and how do i get to it?
  15. ray
    Benefit: Makes a lovely growl :D
    How to get to it: if memory serves, you basically have to dismantle the airbox to get it out.
  16. arthurbikemad
    Be carful with the acc pump settings as you will cause the bike to bog down if incorrect, have it setup on the dyno as it can give you the run round using trial and error! Also it as said fires a squirt of fuel into the motor when you crack open the throttle it's not based on RPM but number of turns of the motor so very small numbers! It's VERY important you set the TPS once installed so load the software and check your throttle position reads 0 and 100% when twisting the throttle from nothing to fully open if not then calibrate it so it does.. defo gut out the intake as makes a good gain. Also go +2 on the rear and you will be in business. Lol.
    Ps... And Ray, you will have your bracket soon :) pps, nice intake....:)
  17. ray
    Did I mention Arthur is a bloody nice bloke as well :D
    Who also guts intakes for a small fee ;)
  18. arthurbikemad
    Lol, shhh, I hate those things....lol
  19. Muffking
    Ive been thinking of getting a pcv for my RR5. I only have a gutted can, +2 rear sprocket & the flapper mod, are the gains that good?
  20. dan.1moore1
    Have you gutted the cat as well or just the box ? De cat'n my bike made more of a power increase than adding a power commander but the power commander made the bike run so much smoother . Depends what your after i guess
