Lamba sensor for 2008 + bike
Discussion in 'Wanted' started by fez.57, Apr 19, 2016.
  1. fez.57
    fez.57 Well-Known Member
    I am after a lamba sensor/ oxygen sensor that fits in the standard exhaust of the 2008 + bikes if anybody has 1 , thanks
  2. ColinBR
    Pretty sure I have 1 in my toolbox mate.
    I'll be able to check on Saturday when I'm back home again.
  3. fez.57
    That's great mate thanks, buggered if I know what I have done with mine
  4. sps170373
    Sure not easier to just get an o2 eliminator? And bolt
  5. fez.57
    Got 1 but have removed my yoshimura and pcv and for some reason it's now throwing a fault code on the dash so was going to remove the o2 eliminator and see if that fixes it
  6. sps170373
    I'd double check the connectors that were unplugged to remove the PCV also just for peace of mind if you haven't already
    You checked what the fault code is?
  7. fez.57
    I have a video but struggling to upload it, it's the engine light will do 2 slow flashes and then go off for a few seconds and then do 2 more slow flashes and just keep going like that, I thought that was a map sensor fault so thought I would have a go with the oxygen sensor
    #7 fez.57, Apr 20, 2016
  8. dansp1
    dansp1 Active Member
    Map sensor is manifold absolute pressure sensor
  9. fez.57
    So what would you suggest the problem is ? Not had the headers off and the exhaust is re fitted ok
  10. dansp1
    Map sensor is on the inlet side, check connection
  11. fez.57
    Yeh on the far right just next to the frame, sure it was all connected properly but will double check it all, thanks
  12. Mr OCD
    Mr OCD Well-Known Member
    I've got a spare lambda sensor (low mileage) if you need it. Drop me a PM for details.
  13. fez.57
    Only other thing I can think of is this, am I right in thinking the hose that is sat on the rear sub frame is a breather and should not be connected to anything . image.jpeg
  14. dansp1
    Hard to tell from the pic but it looks like that could be the vacuum pipe from the map sensor
  15. ColinBR
    Block that off with a screw mate up the pipe. It will be drawing air and causing your fault.
    Pretty sure thats to do with the pair system.
  16. fez.57
    Any ideas where it should go to as I don't remember disconnecting it but just noticed it as it was being put back together
  17. dansp1
    I can't link on my phone but if you are on a pc search sc59 injector bodies on eBay there is a set for sale in Austria with really good pics
  18. ShinySideUp
    ShinySideUp Elite Member
    Isn't that the pipe that plugs in to the map air sensor?
    Connects to the lil tube piece under the blue plug on the airbox in the pic you posted.
  19. fez.57
    That would make sense mate as it's the map sensor that is throwing the fault, hopefully that is the problem
  20. fez.57
    Thanks will go and have a look at that now
