Looking to install a wall/ground anchor. Any suggestions?
Discussion in 'Non Bike Related' started by JRNapalm, May 28, 2020.
  1. JRNapalm
    JRNapalm New Member
    Hi there,
    Any suggestions on these? I got a permit in my parking garage to install an anchor, just looking if anyone has done this job themselves.
  2. BladeOfGlory
    BladeOfGlory Active Member
  3. F1CT1C10U5
    F1CT1C10U5 Well-Known Member
  4. Boothman
    Boothman Elite Member
    Ground anchors are useful (got one myself) but in all honesty the chain you use is always going to be what they cut
    • Agree Agree x 2
  5. PauloHRC
    PauloHRC God Like
    I Have a sunken ground anchor, its flush with the concrete floor in my garage but you'd need to dig a big hole for that.
    is there nothing you can chain it too?o_O
  6. Empty_Ten
    Empty_Ten Active Member
    Any of the heavy duty stuff from Milenco, Almax or Pragmasis.
    I’d for for a chain from any of the above 3 as well, anything with 16mm + links.
  7. Naz
    Naz Active Member
    Have to say most of the ground anchors I’ve seen have been similar quality. I have an Oxford one bolted in my brothers garage and a Y Anchor in my garage which is sunk into the concrete. But as mentioned the chain is the weakest point. If your bolting to the ground you need to make sure you use some good anchor bolts and if you really want to go overboard use some resin with it. If you use crap bolts the whole thing can be ripped out with a little effort and it doesn’t make that much noise
    my opinion is that sinking into the concrete is the best option but there just going to cut your chain if they really want it
    • Agree Agree x 3
  8. Mr_Chin_LK
    Mr_Chin_LK Well-Known Member
    Almax chain and Squire padlock all the way!
    Expensive stuff, but then so's your pride and joy!
    Chin
  9. JRNapalm
    JRNapalm New Member
    Thanks for the suggestions. I'm trying to figure out if it's possible to drill into concrete wall with a regular drill or I need to buy a proper SDS drill for this. Anyone has experience maybe with a regular drill? Looks like for oxford wall anchor I need to drill a 12mm pilot hole and 16mm hole.
  10. Mr_Chin_LK
    Regular drill will do it, but must have the hammer drill option on it.
    Chin
  11. Kentblade
    Kentblade God Like
    Matey don’t mess around with those piddly things that are a nightmare to drill into concrete floors, Mr Chin is spot on, decent Almax or similar with a top Squire lock attached to this bad boy, a proper ground anchor, that will stop the tea leaves in their tracks ;)
    • Funny Funny x 2
  12. Boothman
    You’d only need the lock for that - it’s already got the chain with it :D:D:D
  13. JRNapalm
    JRNapalm New Member
    You recon any cheap hammer drill of amazon would do the job? Saw a few going for as low as 40 euros
  14. Mr_Chin_LK
    Yes, definitely, but must have hammer drill action and a masonry drill bit for the sized bolt being used.
    Chin
  15. hitch
    hitch Elite Member
    Check first that you’ll get a 16mm bit in the Chuck of the drill. 16mm is fairly large.
  16. mk3golfcab
    mk3golfcab Elite Member
    You won’t get a 16mm shank in a normal drill chuck as they are a 1/2”/13mm Chuck. You’d have to get a reduced shank drill bit, I’ve just bought a 14mm drill bit from Screwfix (with a 1/2” shank) something to check out so as to not get the wrong one :)
    • Agree Agree x 2
  17. Brom66
    Brom66 Well-Known Member
