Miscellaneous list of items for sale: Tokico calipers with good pads - SOLD; Generator cover from 12+ in black, mint condition - SOLD; Clutch cover from 08-11 in bronze, good condition - SOLD; Throttle cables and housing - £20; OEM master cylinder without lever (missing bracket bolt and reservoir lid) - SOLD; OEM clutch perch without lever - £10; OEM sprocket cover - £10; Yoshimura inspection cap - SOLD; Ohlins spring from TTX rear shock rated 44/120 - £40; OEM bar ends - £20; OEM rear shock - £65. Cheers!
The one I have to hand is this one. The marks on it are just dust/dirt. Will take another and one inside as well when I get home this evening. It really is in mint condition, no scuffs or scratches to be seen. Bought it to replace my bronze one but found out they aren't compatible with the 08-11 generation.
Ah bit of a Monday morning moment :/ Yes I do mate, will grab some photos this evening for you! If I don't give you a shout by about 7:30pm, please shout at me because chances are I've forgotten
@Dazzler54 here is the photo. The case has no scuffs or marks, no road rash or dinks. It is dirty with the usual stuff, gave it a wipe but not thoroughly. It was still wet when I took the photo.
