Mot reflector solution for tail tidy
Discussion in 'Mods, Upgrades, Accessories and Products' started by Fwsock, Feb 11, 2018.
  1. Fwsock
    Fwsock Active Member
    I’ve been looking at a solution for my mot in that the r&g tail tidy has no reflector. I didn’t fancy one of those button style ones on the number plate. So I bought a cheap reflector of of fleabay. Like this.... E05E3666-C74B-4085-A6DE-C59068472F01.jpeg 43AA2C21-7D94-47CF-891E-6624717313D8.jpeg
    As you can see I attacked it with the dremel. After a wee bit honing on the grinder it was smoothed of and using the sticky on the back I stuck it onto the bit of the number plate light with r&g embossed on it (no free advertising). It now looks like this, which I think is a neat and permanent solution. Also passes an MOT :D
  2. nigelrb
    Interesting. I bought my Blade already MOTd from a dealer. That same dealer will do the next MOT in April. I hadn't even thought of the reflector issue, but now you mention your idea (which I might STEAL and PATENT) I will keep it in mind, although my OCD would see me emery paper the edges into a rounder profile. (Of course I know you are yet to do that:):)).
    In any event, I doubt I would be pinged for it, otherwise I would simply remind the dealer of how it was sold to me.
    I have to go - those uneven numberplate screw holes are annoying me!!:(:(
  3. Fwsock
    Ha ha hadn’t even noticed those lol. Yes I will be rounding of the edges a wee bit. If u do it be careful as reflectors are hollow and brittle. As I found out with the hacksaw before charging up the Dremel. I accept cheques, PayPal and bacs for royalties :D:D:D:D
  4. Fwsock
    Wonder why r&g just don’t make it with a reflector already fitted. Too easy?
  5. tuktuk
    tuktuk Elite Member
    I use a different plate for MOT with a little round one on. Only time it ever sees the bike.
    • Agree Agree x 3
  6. lardytkd
    lardytkd Active Member
    Mine hasn't seen a reflector for a few years and never had an issue with the MOT.
  7. Fwsock
    Depends on the d1ck who does the testing. Mine failed last one before I bought er and they forced a stick on one in place to pass.
  8. Stevie_d
    Stevie_d Senior Member
    R & G tail tides comes with a reflector and bracket , which mounts at the bottom under the reg plate . Unless u bought second hand
  9. CBRGav
    CBRGav Active Member
    Mines stuck on my full size plate too
  10. Stevie_d
    Rectangular reflector with bracket to bolt on under the tail tidy , int box :)
  11. Fwsock
    Interesting Stevie, wasn’t aware of that. Mine was on the bike when I bought it. Previous owner had used the stick on solution for MOT. Maybe it’s a new thing it comes in the box or is it just that people conveniently manage to ‘lose’ the supplied one :D:D
  12. nigelrb
    This issue should not even be a topic because since lights have been 'hardwired' the reflector is redundant. It is a case of legislation not being consistent with MOT laws.
    As usual, it is the public who end up the bunny and have to open their wallet.
  13. hitch
    hitch Elite Member
    I believe the issue of rear reflector is in the event of a rear light failure or, if the bike is parked at night on the road.
    Of course I may be wrong.
  14. stevet
    stevet Active Member
    No dremel needed on mine..like this straight out packet 20180212_152352-1.jpg ....fitted to a r and g tail tidy
  15. BlackDevil
    BlackDevil Elite Member
  16. Fwsock
    That’s a better one steve t. You should post a link for that
  17. stevet
  18. PauloHRC
    PauloHRC God Like
    Well that was a waste of a Sunday afternoon! ! :rolleyes:
    Good effort though :D
  19. nigelrb
    Done and on their way - just in case I need one! Cheers Steve!
  20. Fwsock
    Was bored paolo
