Not running smoothly between 4 to 5000 revs when you’re just cruising, but it’s okay when you celebrating through the Reds, had to spark plugs in Hache T leads checked and had the fuel filter cleaned as it does feel like it’s something to do with the fuel or air intake.....please help .
Hello, welcome to the forum, I would suggest posting https://www.1000rr.co.uk/forums/maintenance.12/ < There for your question. As this section is for "Forum news from the Admin"
@John gower. Welcome to the forum. I'd recommend introducing yourself on the new members page, and then post your problem in the maintenance section. We're very helpful on the whole & will at least point you in the right direction. Put in some bike details & don't trust autocorrect, not unless you want congratulations for being Russian or a Scouser, otherwise it's not your friend! Are you talking about H.T. leads - High Tension leads?
