Boring question I know, but faced with using either an OEM Honda oil filter or K & N (made in China) version, which would you use? I know K & N rate highly with their air filters, but not too much is posted about their oil filters. For what it's worth, I have one of each. No need to ask why; put it down to OCD to evaluate the better product!
Cant comment on the performance but not too keen on the tightening nut on the K&N. When painted it easily rounds off, much prefer OEM
HiFlo are plenty good enough for me. I usually have a few spare, but mainly because they often come with the oil. The nut on the K&N though is to undo the filter as it's known to rupture the can if you use it to tighten the filter.
Always used k&n on mine. No problems getting them off but they generally only see 2k miles between changing.
Another vote for HiFlo used them for years fitted loads to mine and customers bikes, never had an issue
Hadn't considered HiFlo. Too late for this change. I thought the nut on the K & N would be a bonus, but I accept it could be a problem to the heavy-handed. I'll use the OEM and put the K & N in my 'Bonus Box' for when I sell the bike to @Lozzy!
Being from yorkshire I check all the technical specs, look at all the reviews, then get whatever is on offer
Yep, I can well believe that. I've bought a couple of bikes from Yorkshire and seen, first-hand, the results of that philosophy!!
Which bike is it for @nigelrb ?? Will second what others have said about Hiflo. ......used them on the oil changes that I've done myself on other bikes but the Honda always gets serviced by the dealer so gets an oem!
For the 2011, Paulo. It's an interim oil change. Like you, I use dealers for the major work. A lot of it is just a PIA!!
I use hiflo KN etc and do about 2k a year, I think if you are low mileage and go for any of the major brands you wont have an issue
If you drop some metal filings in with the oil @nigelrb then you will know which is the best filter NOOOOOOOOO
