Power commander 5 map switch
Discussion in 'Mods, Upgrades, Accessories and Products' started by Andrew, Apr 7, 2012.
  1. Andrew
    Andrew Active Member
    Before I get my bike mapped I want to get hold of the map switch and handle bar mount that they do.
    I thought that way if i'm on a long trek i'll be able to have a map for best economy, and at the flick of a switch have the full power map.
    Now it might be me being a bit dumb but i'm struggling to find hardly any uk retailers that are stocking them.
    So if you know of a site with them on could you point me in that direction please.
  2. Si.
    I think Motrac racing supply them mate.
    Motrac : Homepage
    If not, ask zeepony... I think he had one???
  3. ColinBR
    Hi there.
    I got mine from CMC bikes. Think it was around the £20 mark. You still need to cut off the end plug and then put the wires into the rear of the powercommander.
  4. ColinBR
    Here's mine when I cut the wires
  5. Andrew
    Cheers for the link I'll give them a call on Tuesday
  6. Andrew
    Oh right I thought it was plug and play, doesn't it seem stupid that you have to cut the plug off something that was made to work with another one of their own products!! :confused:
  7. Andrew
    How rude of me I forgot to say cheers for the pic's and at least it's only to wires even a numpty like me should screw that up
  8. ColinBR
    Yup it does seem stupid, but it was made for the PC3 with the expansion module, which costs another £200 for the PC3. With the PCV it's just a case of trimming the wires and it does the rest without the need for any extra hardware.
  9. Andrew
    How much better is your fuel economy from one map to the other, thats if thats the way you've got it setup?
  10. ColinBR
    Haven't had the chance to get mine set up yet.
    I'm going a different route though. I'm going to get mine tuned for baffle in, baffle out.
  11. Andrew
    I know with the map i'm using at the minute from the power commader site my bike is drink fuel like theres no tomorrow.
    I think it was around 30 miles less on a tank than before I fitted it
  12. ColinBR
    To be honest you'll get more mpg once it has been properly set up on the dyno anyway. I noticed a difference when I had my last bike setup. I went straight from standard to dyno'd and easily got another 10 miles to the tank even with the extra power
  13. Si.
    What Colin said. Looking at the map I had done, I noticed a lot of fuel was taken out in various stages of the rev range, not added....
    I haven't noticed any extra fuel used, still does 120miles before the light comes on, 150 taking it easy with A roads.
  14. Andrew
    That sounds great I can't wait to get it booked in now
  15. arthurbikemad
    I have a couple of DJ map switches they are very cheaply made but seem to keep working, IMO you can fit much better for half the money after all any switch will do! It's down to the dyno opp to make a good fuel econ map for you to use or it's a waist of time, tbh I have done just this before and run the bike very lean IMO it does not save any fuel your best fuel econ mode is on the end of your right arm.. ;)
  16. Andrew
    When you say you have a couple, do you mean for sale?
    What would be your suggestion as an alternative mate?
  17. arthurbikemad
    Sorry mate my lazy posts...lol no I have a couple on my bikes one on PC3 for dual map and one on a pcv to turn autotune on and off, there are some good waterproof switches on the dreaded eBay that I use a couple of times before or any simple switch like I installed on zeeponys bike to test maps etc.
