Rain light with tips for wiring
Discussion in 'Racing & Bike Sport' started by wedgiewolves#223, Nov 19, 2014.
  1. wedgiewolves#223
    wedgiewolves#223 God Like
    Sorry but i pinched this from Motoforum id have never thought of this but helpful if like me my wiring skills aint the best ha ha ....
    I was going to get a battery one but if ACU follow FIM rules it states you must be able to turn switch on and off seated on the bike you probably could but faffing about i dont want ...
    I ordered this switch got 2 just incase
    Universal Motorcycle Kill ON-OFF Switch Button Handlebar Mount Bullet Connector | eBay
    This rear light i was going to get from the NEC but thought sod it
    Borealis Safetylight SL2 Racing Safety Brake Light
    Really good idea wiring straight to your original brake light and onto the brake light switch wires i would of never thought of that ha ha .
    Tips for a simple installation of a rain light if you are using a stock harness
    Your rainlight will come with 2 wires, connect as follows to original bike rear light wiring at rear of the bike:
    Suzuki + White/Black – Black/White
    Honda + Green/Yellow -Green
    Kawasaki + Blue/Red –Black Yellow
    Yamaha + Yellow – Black
    Get a simple switch (EBay £14 for a handle bar mounted one/ £3 for a toggle switch)
    Connect the 2 wires from the switch to the wires going to the front brake
    switch.
    A simple installation, no extra wiring, it’s fused, safe & scrutineer proof
    If your bike has diffent coloured wires pm me & I'll let you know which ones to use
  2. Jimbo Vills
    Thanks Champ! looks like the way forward for me....
    Dave V better read this pronto ;)
  3. wedgiewolves#223
    Yeah and me even i cant fu............ no not gonna say it ha ha
  4. Jase
    Jase Elite Member
    I decided on this light as its a lot smaller than that one of yours wedgie they are out of stock till next week but cheers for the switch link will Order 2 of them as well .
    http://www.ebay.co.uk/itm/141155468731
    #4 Jase, Nov 19, 2014
  5. wedgiewolves#223
    They have to be a certain size mate I don't know whether it will even matter at scrut but if you look at size of them it's not that big pics make them look bigger than they are that's next to a 50 p ImageUploadedByTapatalk1416418064.594000.jpg
  6. Jase
    Jase Elite Member
    Not according to the ACU regs as long as it can be seen.
  7. Jase
    Jase Elite Member
    For 2015 Red Rear Warning Lights will be a requirement for solo road race machines. Classic and Vintage machines racing exclusively in their own races or events are exempt.
    The requirements for these lights are as follows,
    All motorcycles must have a functioning red light mounted at the rear of the machine to be used in rain or low visibility conditions as instructed by Race Control. The team must ensure that the light is switched on whenever a rain tyre is fitted on the motorcycle and/or when any practice or race is declared “wet” by Race Control.
    Lights must comply with the following:
    a) lighting direction must be parallel to the machine centre line (motorcycle running direction), and clearly visible from the rear at least 15 degrees to both left and right sides of the machine centre line.
    b) mounted on the seat/rear bodywork approximately on the machine centre line, in a position approved by the Chief Technical Officer. In case of dispute over the mounting position or visibility, the decision of the Chief Technical Officer will be final.
    c) power output/luminosity equivalent to approximately: 10 – 15W (incandescent) 0.6 – 1.8 W (LED).
    d) the switch must be accessible.
    e) rain light power supply may be separated from the motorcycle main wiring and battery.
  8. wedgiewolves#223
    Ah sweet top stuff
  9. Souleh
    Souleh Active Member
    bicycle light 99p lol
  10. frizz
    frizz New Member
    would like to see these mounted to your tail unit please if you have a 2008 / 2010 blade as the seat unit isnt flat underneath apart from where the original light would go
  11. Souleh
    Just get a bracket or an old tail tidy in my case
  12. IcarusGreen
    IcarusGreen Elite Member
