Ram mount
Discussion in 'Mods, Upgrades, Accessories and Products' started by Boo634, May 15, 2014.
  1. Boo634
    Boo634 New Member
    Hi everyone trying to fix a ram yoke mount for a Sat Nav but the two I've tried are not big enough for my 09 blade any body no if anyone else does them for that size many thanks Boo
  2. Silverback
    Silverback Member
    Bob at Telferizer.com does them
  3. Peter
    Peter Active Member
    Boo, can you attach the picture of your RAM mount?
    There are several versions, and it would be helpful to know which one you're trying to fit.
    I have the same year '09 model and had a similar problem last year... but finally I found this: The Telferizer Custom Motorcycle RAM mounts for GPS Systems
    It is brilliant, simple, easy to fit, highly recommended ;)
  4. Si.
    +1 for the Telferizer mount.
  5. Tom68
    Tom68 Active Member
    Get in touch with Bob at Telferizer, Top Bloke. A few of us have had them off him. :D
  6. Boo634
    Boo634 New Member
    Thanks for the replies I managed to use the u bolt supplied with the sat nav to mount it gonna be using a tank bag so this puts it in a better position Boo
  7. djmrmagic
    djmrmagic Active Member
    +1 for Bob at Telferizer had 3 mounts off him for blade, cbr600rr and speed triple :)
  8. Remal
    Sorry to bring this up but I just PM'ed Bob re a yoke mount as I want one to use my go pro with
    Good heads up all
  9. Ramsay
    Ramsay Active Member
    I use this RAM Mount for the fork stem for my Zumo 660
    The inner diameter of the SC59 fork stem is 24 mm (0.944 inch). That's why I had to use the top piece of rubber (1:05 in the video). The top piece has a diameter of 28 mm and has to be conical in shape so that it fits in the fork stem.
    Use a power drill and a file to form it. Works quite well.
  10. Remal
    What can I say about Bob at Telferizer. Sent off a email enquiry and within 10 mins he's called me, explained what he does, and what he can do for go pro mounts and sending over some pics for me to look at
    Top suggestion and service
  11. Daron
    Daron New Member
    are the 600rr and blade a different size stem mount?
  12. BlackDevil
    BlackDevil Elite Member
    Telferizer
  13. Andropheonix
    Andropheonix New Member
    Ah, that's exactly what I want, better email this guy I guess! Thanks a lot :)
  14. chrisleo
    chrisleo New Member
    Fantastic guy, got one for the blade and Ducati Streetfighter, posts them over seas, fast service...top bloke.
