Rubbing/warped brake disc
Discussion in 'Maintenance' started by Jess, Jul 22, 2017.
  1. Jess
    Jess New Member
    Hey guys. I have a rr6 and when I'm pushing the bike the front brake seems to grind at a certain point in the rotation. Im assuming this means I have a warped disk? Is there any way to check and would people change both discs, or just the one?
  2. sps170373
    Might be the buttons have seized get yourself an 8mm flange bolt and nut and free the buttons first then see if you still have the same problem after!
    It's just a case of nipping the bolt and nut onto the button then turn with a spanner or socket and squirt brake cleaner onto the buttons
    Plenty of videos on you tube how to do it
    If it doesn't help it's a case of seeing if the disc's have more than 0.3mm runout using an dial indicator
    Always replace discs as a pair! Not worth just doing one
  3. Jess
    Jess New Member
    Thanks I'll look into it :)
  4. Jess
    Jess New Member
    Just checked my buttons and they appear to be completely stiff. In the video on YouTube the gut can rotate with his fingers. Guessing plenty of cleaning should free them uo to that level and maybe fix the issue?
  5. sps170373
    Once you eliminate the buttons not moving you might find that the discs isnt warped! Start with those first and if that doesn't work then check the runout, simple process of elimination
