running temp on fireblade 2010
Discussion in 'Maintenance' started by Pow37s, Jul 9, 2017.
  1. Pow37s
    Pow37s New Member
    Hi all,
    just changed the oil and coolant, took the thermostat off to see if working... as the bike was running hot. it seems to have not done much as it still runs quite hot... gets up to about 82c pretty fast then if in slow town traffic goes up 90 - 94c. fans do kick in when stopped at 102c.
    just wondering if this temp is normal, what do you get on your bikes?
    cheers
  2. Great Guy
    Great Guy Well-Known Member
    Mine runs at 78 C when on open roads. Get very hot in slow traffic 100+
  3. andreww
    andreww Active Member
    Sounds normal to me
    Mine same as that. Bear in mind the ambient temperature is high too at present.
  4. Mr OCD
    Mr OCD Well-Known Member
    Same.
    76-78 on a run ... gets up to 100+ quickly in traffic but tans always keep it below 106.
  5. Mr OCD
    Same.
  6. Buzznuts
    Buzznuts New Member
    I have noticed the same temp ranges on my my 2005 blade and was gonna query the same thing..........however if the 2010 does it then I can only assume the temp ranges and characteristics are perfect if they are still the same 5 years on!
    at least my mind us at rest fir now!
  7. bonjo
    bonjo Active Member
    82 is on the high side for normal running temp. I get 80 at high motorway speeds in warm summer weather (30deg). In winter, anywhere between 75~78 but in stationary or crawling traffic, the temperatures goes up quickly to where the first fan kicks in.
    BTW I have a rad guard which could affect the airflow.
  8. Frankblue
    Frankblue New Member
    Temp ranges havn't altered much over the models and years. My 16 blade shows high 70s to low 80s on a run, quickly rises above 100 in traffic but fans do kick in at 103 and 106. I found it a bit worrying at first but apparantly its normal. Temp soon comes down when on the move again.
  9. Pow37s
    Pow37s New Member
    awesome to have so many reply, my mind is at ease now that it seems normal. cheers
  10. dave the rave
    dave the rave Active Member
    same as mine 2011 blade
  11. Lozzy
    Quite warm here today...mine was running around 77 on the national speed limit's, then into the 80's for the lower speeds & quickly into the 100+ on urban crawl. Always been same since ive had it.
    Mines an 11 with a rad guard
