You'll need to read the DTC codes. The plug is under the battery (red plug) short it with a paper clip and turn the ignition on. the dash light will flash and give an indication of the error. Potentially you might have knocked one of the sensors perhaps?
I assume the slotted rings are still on the wheels, and the front is the right way round. Maybe a pic or two might help with diagnosis
