The effect of Brake cleaner on Brake seals!!
Discussion in 'Maintenance' started by Slick, Apr 22, 2020.
  1. Slick
    Slick Elite Member
    Left some OEM brake caliper seals in ACF corrosion block and Brake cleaner for 12 hours.
    Left control
    Middle ACF corrosion block
    Right Brake cleaner.
    The results speak for themselves!!!. Extreme conditions but just be aware!!!!
    • Useful Useful x 4
  2. RR7
    RR7 New Member
    What make of brake cleaner did you use?
  3. Slick
    Slick Elite Member
    It was halford's own out of a can.
    Just had some Wurth cleaner ( the one in a bottle not can) delivered too so might repeat using that too
  4. RR7
    RR7 New Member
    That's really concerning. If we can't assume brake cleaner is safe on exposed brake parts we are a bit screwed.
    Mine is Normfest MC1, I got it from Europarts but remember the lad asking me if I wanted the cheap stuff or proper gear.
    • Agree Agree x 2
  5. Slick
    Slick Elite Member
    I'm servicing the calipers at the moment, I have highly polished stainless steel pistons which are normally smooth as butter to remove but after liberally soaking the calipers with the cleaner they were PITA to remove.
    I'll repeat the experiment with Wurth cleaner to see if the same happens.
    Incidentally I have exactly the same issues after spraying the calipers in WD silicon spray. Once serviced sprayed the calipers in the stuff, replaced pads and tested, the travel on the lever was massive (this was with a RCS19) which was set up on a short throw. Had to pump the lever to get full braking. Took the calipers apart to find the dust seals had expanded and were being pulled out!
    https://www.1000rr.co.uk/threads/tokico-brake-pistons-in-stainless-steel.33942/#post-452412
  6. Slick
    Slick Elite Member
    Checked out Wurth brake cleaner against OEM seals
    The bottle actually had a warning!
    This is the result after only an hour soaked in the solvent, expanded the same amount as with cheapo halfords brake cleaner
    I used to be quite liberal with this stuff, now will use with caution
    #6 Slick, Apr 23, 2020
  7. raphael
    raphael Elite Member
    Think I’ll go back to hot soapy liquid and a tooth brush mate:D:D
    • Agree Agree x 2
  8. Slick
    Slick Elite Member
    Absolutely, water based seems to be safer!
    I fecked up a DID chain in 6months, xring started splitting, was using wurth at the time. Wurth chain cleaner is also labeled as brake cleaner, wondering if this was the cause, another test in order!
  9. Lozzy
    Yes do a test...
    I use Wurth chain cleaner all the time :eek:
    I've got a cupboard full of it :confused:
  10. RR7
    RR7 New Member
    There's a guy on YouTube goes by the name FortNine. He's done some great tests on chain cleaners and O rings. Not exactly brake parts but I bet similar.
    His only recommended chain cleaner was Ipone brand and his best overall chain lube was 80/90 gear oil.
    I use both and have to say the cleaner is mustard, and the oil, well it smells when the chain gets warm but seems to work.
  11. Selmer50mark
    Selmer50mark God Like
    Lol, ,,,, ya daft bugger :D:D:D:D:D
    #11 Selmer50mark, Apr 23, 2020
  12. Slick
    Slick Elite Member
    Just watched this and very interesting, based on his lube recommendation did use gear oil for a bit but moved on to XCP now.
    Never really thought that much about the cleaner but generally only use Wurth cleaner
    I've just changed my chain and sprockets as part of my lockdown service so will take apart a few links to see it it has effected the lube in the sealed areas.
  13. Mr_Chin_LK
    Mr_Chin_LK Well-Known Member
    Being the chain cleaning guru of the forum, paraffin not only works a treat, it doesn't eat away at o rings and is cheap as chips at c.£8 for 4 litres. I've never bought any branded type cleaners for my chain, always used paraffin from boy to the idiot I am now!
    A bit off topic, but my 10 pence Wurth, soz.
    Chin
  14. Slick
    Slick Elite Member
    To be fair I've been using Wurth dry lube and cleaner forever and only one chain has been killed prematurely. I don't really count the miles but its normally 2 winters before they need replacing
    The supplier reckoned it was a bad batch of chains and I got a new one under warranty
  15. Lozzy
    Same here I've used it for ages all year round and my chains have always lasted and seemed ok
  16. bonjo
    bonjo Active Member
    Slick
    I am not surprised about your findings. I would never soak the rubber seals in brake cleaner (unless specifically told by the manufacturer). In fact I would not use it on anything other than bare metal (e.g disc), cleaning up greasy nuts & bolts or removing tar spots.
    I have also stopped using wurth cleaner on my chain because I am not sure of the effect of spraying high pressure solvent onto the O rings; I use kerosen.
    I thought you use brake fluid to lube or clean the seals (???). Or the special grease to lubricate
  17. Slick
    Slick Elite Member
    Yes that's true and I don't specifically clean the seals with brake cleaner just a strong water based degreaser but I do liberally spray the discs when during the bobbins and clean the calipers before re greasing, but I have to admit I'm not particularity careful were it goes.
    Normally I use brake fluid on the pressure seal and red grease or silicon on the dust seal but was experimenting with alternatives (ACF corrosion block) as these greases are not particularly resistance to everyday riding. BTW I'm not recommending corrosion block just experimenting.
    In another thread I mentioned I used copper slip on the backs of the pads, for reasons mentioned there could be better out there, I'm also experimenting with alternative specifically which are more resistance to my personal detailing regime!
    I have stopped spraying cleaner directly on the chain, for the reasons you mentioned, I normally spray on a micro fibre and wipe off, seems to be more effective and efficient. I believe Wurth chain lube requires a very clean chain to be applied, this is why the cleaner is particularly strong, others may leave a oily residue which makes the lube less effective. In anycase I use XCP now which is much less fussy with how clean the chain is.
  18. RR7
    RR7 New Member
    My Normfest is acetone free. I think that is relevant. I'm sure I've been here before and acetone is the constituent that swells rubbers.
  19. Slick
    Slick Elite Member
    Both Wurth in the can and bottle are acetone free too.
    The burb also says 'Good material compatibility with paints, plastics, seals and rubber' just not brake seals lol
  20. bonjo
    bonjo Active Member
    I applaud the elbow grease you put in your detailing experiences and sharing them with us:)
    I find them very helpful; the do's as well as the don'ts
    BTW about cleaning the disc bobins, is it a routine task or to avoid braking problems?
