Tru-tension and muc-off extreme
Discussion in 'Maintenance' started by bazzashadow, May 12, 2019.
  1. bazzashadow
    bazzashadow Elite Member
    as heading I have been using a can of Motul c2 and do not like it so I was wondering if anyone has tried
    Tru-tension bananaslip
    Or muc-off extreme
    And if so what one and what do you recon?
    Thanks
  2. Selmer50mark
    Selmer50mark God Like
    No
  3. bazzashadow
    Thanks mark
    Now I know why your mates( or what ever you might be because I can’t get to the bottom of it;)) with Lozzy;);):p:p:p:p:p:p:p
  4. Selmer50mark
  5. Lozzy
    Ffs :eek::eek::eek:
    Do you go out of your way to find the most bizarre products that no one else ever uses :rolleyes: :D
    WURTH DRY CHAIN LUBE ;)
    • Funny Funny x 2
  6. AndrewQ
    AndrewQ New Member
    Hey, so I have tried Tru-Tension Bananaslip (bought it with the chain monkey, which I have to say I love because on the little Ducati as getting the chain tension right is a pain in the hole, and found it works well on the Honda too).
    The only real bonus is that it smells nice. I used the lube rather than the wax, and it goes on easy as it doesnt spray everywhere and so can be directed easily enough, is clear(ish) and is well priced. BUT, I also found that on the back roads, it seemed to let all the road grime stick to the chain, so the chain would need to be cleaned regularly before re-application.
    I also found that despite its claimed "non-flick" properties, I ended up with A LOT of sticky lumps being thrown up on to my rims and under-seat section (granted, I may have been rather to liberal with application?).
    Lastly, I usually do my chains on a Saturday. One week I did not, so it went two weeks without being cleaned/lubed, which would equal 250 miles of motorway and country lanes (50/50). After the two weeks, I could see rust starting to appear on the chain.
    I used it simply as it came with the tensioning tool as part of a bundle, and I really like the tool, but the lube I found a bit naff and it was donated away.
    Now, my DID chain recommends using a high quality mineral/gear oil.
    "Lubricant should be a mineral oil of good quality. It is important that the lubricant contains no dust or foreign substance. Never use waste oil."
    So that is what I now use. I always have good quality oil available for the bikes, and have found it to be far better and protecting the chain than any expensive lubes/wax options. Applied with a soft brush, leaves the chain looking like new.
    In fact, there is also this video that was done by FortNine which shows a test being done from several different options which might be useful.
    Certainly cemented my views on using oil as my first choice.
    Hope that helps!
  7. Lozzy
    We're just mates Bazza..we're not closely related.....
    unlike the whole of Norfolk :D
  8. CBRGav
    CBRGav Active Member
    +1 wurth stuff is awesome
  9. nigelrb
    Yep, I have another can en-route from Sportsbikeshop with my Rentec stand:).
  10. bazzashadow
    You should know I don’t like dry lube;);):p:p:p
    • Optimistic Optimistic x 1
  11. Lozzy
    Carry on being a mucky splatterer then :rolleyes:
    :D
  12. bazzashadow
    ;):p:p:p:p:p:p
  13. bazzashadow
    You told us You keep hearing “Lozzy put so lube on that”;)
    :p:p:p:p
  14. bazzashadow
    Lovely job mate
    More help than the other reply’s I got;);):p:p:D
  15. nigelrb
    Yes, but Andrew was new then and didn't know not to treat you seriously!:rolleyes:;)
    • Funny Funny x 2
  16. Lozzy
    No it wasn't. ..all Andrew said in a polite roundabout way was...tried it..it was shite..gave it away to some other sucker lol
  17. Selmer50mark
    Gear oil every time ;)
  18. bazzashadow
    Now you want to comment;);):p:p:p:p:p:p
  19. bazzashadow
    Yep
    Very helpful
    I hate bananas anyway:mad:
  20. Lozzy
    But you don't hate Kelly ;).....and Kelly says. ...
    • Funny Funny x 2
