yoshi spitting flames.... is it the cold?!?
Discussion in 'Pictures & Videos' started by navvy10, Dec 19, 2013.
  1. navvy10
    navvy10 Well-Known Member
    Just fitted the R&G engine covers and started her up and she's spitting flames :)
  2. ShinySideUp
    ShinySideUp Elite Member
    Is your pair valve unit still connected or has it been bypassed?
    My bike used to spit huge flames until I bypasses the pair unit from dumping air into the exhaust which is what's allowing any unburnt fuel igniting and spitting the flames. That's the pair units job, introduce extra air for the cat to work correctly and burn off any extra fuel mixture before the gases get to the cat converter.
    Bad fuelling specifically over fuelling can also cause it if the pair system has been bypassed/deactivated.
    #2 ShinySideUp, Dec 19, 2013
  3. navvy10
    The PAIR mod has been done mate. Might check the PCV is working ok tomorrow and if so then it's just down to the cold weather making the mix richer I guess. I've got a remap also
  4. flynn07
    flynn07 New Member
    Leave it , it looks mint:D
  5. Nutty Tart
    Nutty Tart Well-Known Member
    Yea +1 on that ^^^^^^^
    Awesome
  6. ShinySideUp
    I wouldn't worry too much about it mate, even the most highly tuned bikes that run in WSB/BSB blow flames out the exhaust from time to time on deceleration/overrun but these flames would never become apparent to standard bikes due to the standard exhaust and cat holding the gases back slightly and by the time the gases get through the more restricted OEM exhaust the gases have burnt off extinguishing the flame.
    The stock ECU will also be changing the internal fuel map slightly to compensate for the colder denser air (possibly higher humidity also) which may be knocking your power commander map off slightly!
    Have you ridden the bike out on the road? Does it surge and lurch while riding? If not I wouldn't worry about it unless it still does it when the weather temps come back up.
    You could like you mention check the PC is ok and has not lost the map or something else that could be affecting the fuelling.
    #6 ShinySideUp, Dec 20, 2013
  7. bradt
    bradt Elite Member
    Beats flashing lights on the Christmas tree
  8. Jamiestrada
    Couldn't agree more Brad looks cool
  9. Jimbo Vills
    My Leo sounds better and makes bigger flames....
    Just saying like, it's not a competition or anything. No need to start a poll!! Lol ;)
  10. And7rp2
    And7rp2 Elite Member
    Mint TFA
  11. sps170373
    It's a black bike navvy! Mean, moody and makes loads of power
  12. Cableguy
    Cableguy New Member
    Now , where did I put the marshmallows ;-)
  13. Gilesy
    Gilesy Elite Member
    Only problem with that is you might start melting the carbon infil. I remember a thread on here a few months back about the same thing..
  14. navvy10
    No melting issues at all so far mate :)
  15. navvy10
    HAHAHA I can't believe I missed this me old mucka :D
    Yes you won fair and square but maybe things have changed since and we need to do a new poll to confirm :)
  16. Jimbo Vills
    Sure, only takes 5 secs to sling the Leo back on! :)
  17. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    bumders....
  18. rab
    rab Well-Known Member
    mines spits flames with the yoshi on it never caused any bother yet:D
  19. sps170373
    Now now don't get jealous ;)
