cbr engine noise
Discussion in 'General 1000RR Discussion' started by Strim, Oct 9, 2012.
  1. Strim
    Strim New Member
  2. stuart_g
    stuart_g Active Member
    Sounds perfectly normal to me :)
  3. Jase
    Jase Elite Member
    I can hear the whining noise you are on about , but will leave it to one of the experts on here to comment .
    Listening to it again it sounds like a bad bearing or some sort or clutch problem ,is it just from cold or does it do it when the bike is hot .
    #3 Jase, Oct 9, 2012
  4. wedgiewolves#223
    wedgiewolves#223 God Like
    see if the noise you can hear goes away with the clutch pulled in if it does its a cbr thing they all make a bit of noise . Sounds normal to me
  5. Corki
    Corki Active Member
  6. Jase
    Jase Elite Member
  7. Carl
    Carl Well-Known Member
    It sounds fine to me, a new bike always make sounds that you need to settle with.
  8. fez.57
    fez.57 Well-Known Member
    I cant hear anything out of place there. sounds just fine
    but if you want to get rid of that noise just buy a straight through exhaust system, that might do the trick
  9. Si.
    sounds ok to me......
  10. BLAGGERS
    BLAGGERS Well-Known Member
    It's whirly things spinning around. Only cure is a fruity pipe so as ya cant hear them.
  11. Jase
    Jase Elite Member
    After reading this I went and had a listen to my bike and got to say it pretty much sounds the same as yours so as the others have said all seems ok,if your bothered by it take it to a Garage or if you know anyone with the same bike have a listen to there's.
  12. 1000rr73
    1000rr73 Active Member
    Sounds like my last 2 08+ blades.....I worried a bit initially but I think they all sound like it now.
  13. phantom
    phantom Active Member
    sounds okay to me.the new blades do have a few odd noises,
    still getting used to the low slung exhaust...keep swearing I have a blow out
  14. Haggler ®™
    Haggler ®™ Active Member
    Balance shaft adjustment................................Same type of noise as the Blackbird have if the shaft is a tad too tight. A m8 complained his was whinnnnnnnnnning like a goodun the other year,we took it to my Honda trained guy,he adjusted it and the noise completly went.Theres a section in the workshop manual which covers the adjustment.I adjusted mine last season (not that it whinned but the engine had a rattle), it only takes a few mins once you can get to the adjuster (n/s lower front area)
  15. Strim
    Strim New Member
  16. callumw
    callumw Active Member
    Mine makes the same noise, but less so when it's warmed up (RR-A '60 plate with 5.5k on the clock).
    Giving it beans in 2nd gear, it whines like a supercharger, but not in any of the other gears
    Hope that's useful?
  17. nyscooby
    nyscooby New Member
    Resurrecting an old post and after searching, there's a few misc comments, but is the recall notice on this thread a UK recall or just USA?
    My 2008 does make same said whirring noise. I'm interested in seeing if Honda have an actual recall in the UK for it.
  18. Dave
    Dave Member
    Sounds fine to me, you have to take into account the way gears are cut on high performance engines this makes for a lot of whining/ whirring noises. Could try a little movement on the balancer shaft just to see if the noise changes.;)
  19. Spartan Andy
    Spartan Andy Active Member
    My CBR has just over 150 miles so far from new and it sounds about the same as on the video link.
  20. nyscooby
    nyscooby New Member
    I just oiled the chain. Sounds less whiny. But still whiny.
    Past caring. Still works.
