Fitting a tail tidy
Discussion in 'Mods, Upgrades, Accessories and Products' started by Kevin1, Mar 27, 2014.
  1. Kevin1
    Kevin1 Elite Member
    Well, I've finally got round to actually shaking off a bit of the CBA syndrome and fitting a tail tidy. I'd forgotten what it was like to perform key hole surgery on a bike. Now don't get me wrong I used to perform major surgery on my and other peoples bikes. What a pain in the arse it was to just get at and remove the indicator connector block. Anyway I finally got at it and managed to remove the old number plate hanger. Then there's splitting the number plate hanger, to get at the indicator connector block. I must admit I did consider taking it in and paying but then thought no! I will not be beaten this is nothing compared to what i used to do. I think that was a bit of CBA creeping in again. I eventually gave up for the evening hopefully I'll get it completed tomorrow night, but probably won't. I'll need to see what I will have to do to connect the new number plate light, I am always a bit loath the start messing with the wiring loom but it looks like I'll have no choice.
  2. graemewalker
    graemewalker Elite Member
    If it r and g it's already to plug and play no wire cutting there but evotech you need to cut but at least evotech is better quality
  3. The.kickboxer
    The.kickboxer Active Member
    Jeez, what's all the fuss about, took me 30 mins tops and that included crimp connecting the indicators and plate LED.
  4. Kevin1
    Kevin1 Elite Member
    I don't know if there's a difference but mines an ABS. The tail tidy is Mustard Bikes from Tasmania, just to be different.
  5. The.kickboxer
    That's what I bought too
  6. Kevin1
    Kevin1 Elite Member
    I'm obviously a bit rusty. Have you got any pics of where you crimped the wires and which ones you crimped, kickboxer? Pity you live in Ipswich you could've done it for me. I take it it isn't possible to use the original anti vibration rubbers?
    #6 Kevin1, Mar 27, 2014
  7. Kevin1
    Kevin1 Elite Member
    Tail tidy is now fitted. I worked out that if I took the rear light plug apart I would not have to cut into the wiring loom. So I took the plug apart and crimped the new wires into the old rear light plug then reassembled it. See pic. Quality of pics not great as I just used my phone for them.
    IMG_1395[1] by rushforthk, on Flickr
    IMG_1401[1] by rushforthk, on Flickr
    IMG_1402[1] by rushforthk, on Flickr
    IMG_1397[1] by rushforthk, on Flickr
    IMG_1399[1] by rushforthk, on Flickr
    IMG_1403[1] by rushforthk, on Flickr
  8. rosier1uk
    rosier1uk Active Member
    Looks the dogs nuts that
  9. Kevin1
    Kevin1 Elite Member
    out of the box
    First Impressions. Well made good quality bracket
    Reasonably easy to fit too.
    <iframe src="https://www.flickr.com/photos/116402563@N07/13493683714/in/photostream/player/" width="500" height="375" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    <iframe src="https://www.flickr.com/photos/116402563@N07/13493359583/in/photostream/player/" width="1600" height="1200" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    <iframe src="https://www.flickr.com/photos/116402563@N07/13493683714/in/photostream/player/>
    I am not sure why the links aren't working.
    #9 Kevin1, Mar 29, 2014
