Gopro camera
Discussion in 'Mods, Upgrades, Accessories and Products' started by collier32, Jul 5, 2014.
  1. collier32
    collier32 Member
    After a lot of pondering I've finally got myself a Gopro camera £259.99 from Argos for the hero3 black edition just got to decide where to mount it . Is the picture good if it's mounted on top of my helmet and do people just rely on the stick on mount .
  2. ColinBR
    The stick on mounts are by far the best. Once stuck you ain't getting it off in a hurry.
    I have a mount on my helmet, and also on the nose cone of my bike. Both are fine.
  3. navvy10
    navvy10 Well-Known Member
    Agree with Colin mate the sticky tabs are the best IMO. I found the helmet mounting go for recording everything you see but at speed it becomes a sale and gives you neck ache. I typically mount mine on the side fairing especially for track days.
    Use the waterproof back most of the time or you get excessive wind noise.
    I also go for maximum frame rate for smooth videos. 60fps is great ;)
  4. lambchops
    lambchops Elite Member
    If you want it on your helmet chin is the best area, doesn't catch the wind then :)
  5. Stevie_d
    Stevie_d Senior Member
    I want a gyroscopic onboard camera, how much are they ?
  6. Barstewardsquad
    Build your own :)
  7. Remal
    As long as you mount it on a area that will not vibrate a lot your fine. I have found on the side fairing is good. the best is sticky pad facing back on the side of the front nose
  8. Remal
    or on the nose
  9. Remal
    using the sucker on the tank
  10. Remal
    on the side fairing
  11. Remal
    or on your lid
    hope that gives you a few ideas on where I have tried mine over the years
  12. collier32
    collier32 Member
    Thanks guys I'm thinking of on the side of the air intake just above the fairing so the camera sits in front of the brake lever
  13. Remal
    if that's like my first vid that is the best one I have found so far. I have the sucker mount fitted into the rev counter today so I can try it out tonight when I'm out after work with a mate. It's facing backwards so you can see ME lol but will be trying a few different ways tonight
  14. collier32
    collier32 Member
    This is where I decided to mount the gopro on my bike
