Removing fuel hose from tank?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Mr OCD, Nov 27, 2014.
  1. Mr OCD
    Mr OCD Well-Known Member
    Removing tank to install PCV... How the heck does the fuel hose come off? Some weird clip that won't release?
  2. Muffking
    If it's the one with the metal clip, stick a very thin screwdriver between the clip and plastic part then prize the metal clip outwards to release the pipe.
  3. scooby
    scooby Elite Member
    if it's the red clip type thing,just push the 2 tabs in and lift the red centre out,then pull it off.
  4. Mr OCD
    Green clip?
  5. Mr OCD
  6. Mr OCD
    Done it ... :)
  7. sps170373
    Was going to advise wearing safety specs while doing it, cos the fuel always seems to flick out
  8. Slick
    make sure you connect the TPS connector to the TPS and not the MAP sensor.......
  9. Mr OCD
    They only go one way round?
  10. Mr OCD
    At least I hope so lol ... :D
    Runs and sounds fine ... PCV and O2 eliminator installed and then mapped.
  11. Slick
    nope they are the same connector only a few inches from each other!
    You will know if you get it wrong when the TP% doesn't change
  12. Mr OCD
    Well the ECM light would be flashing wouldn't it?
    I've run it up to temp and sounds fine.
  13. Slick
    I don't remember any lights (when I fecked up!) but when you calibrate the throttle the voltage will not change
  14. Mr OCD
    Bollocks ... Gonna have to check now!
  15. Slick
    Just to add the engine doesn't need to be running to calibrate the throttle (unlike suzukis!)
  16. Mr OCD
    Why would I need to calibrate throttle?
  17. Slick
    The PC needs to know the min voltage and max voltage of the TPS to calculate 0-100% throttle.
  18. Mr OCD
    How's this done?
  19. Slick
    You check without having to calibrate.
    plug in the PC usb to a laptop with the bike ignition on. The DJ software should read 0% with zero throttle and only 100% when you give it the full beans. If it reaches 100% before full twist or doesn't reach 100% you need to calibrate
    #19 Slick, Nov 27, 2014
  20. wedgiewolves#223
    wedgiewolves#223 God Like
    Plug your laptop into PC with software and roll throttle on ? Is this correct ?
