Removing tank to install PCV... How the heck does the fuel hose come off? Some weird clip that won't release?
If it's the one with the metal clip, stick a very thin screwdriver between the clip and plastic part then prize the metal clip outwards to release the pipe.
if it's the red clip type thing,just push the 2 tabs in and lift the red centre out,then pull it off.
nope they are the same connector only a few inches from each other! You will know if you get it wrong when the TP% doesn't change
I don't remember any lights (when I fecked up!) but when you calibrate the throttle the voltage will not change
You check without having to calibrate. plug in the PC usb to a laptop with the bike ignition on. The DJ software should read 0% with zero throttle and only 100% when you give it the full beans. If it reaches 100% before full twist or doesn't reach 100% you need to calibrate
